Thank you for the information.I am new to this field of anodizing.I also don't know about 720 rules.Please tell me deiaily about this.
Web Design Services |
I'm not sure I understand the calulations correct me where I'm wrong.
1) Is the amount of acid bath/ano tank used for calulating time? 2) The Sq Ft. of the part and racking need to be known first? 3) Is 20 ASF the standard for ano, or is 4.75 I recall that number from caswells site somewhere. 4) From what I understand my part is aprox. 81 Sq. Inches or .57 Sq. Ft. So to ano 5 mils for 18 min I would need 11.4 amps @ 18.93 Volts. Or 1 mil thick for 90 mins would be 2.7 amps @ 4.48 volts. this is the largest part I will be have to ano, so I'm using this as a starting place to get my setup going. 5) Also would there be any noticable changes in using lower voltage/amperage over using higher voltage/amperage, or is it just for times sake? any help is appreciated. thanks -Matt |
Thanks so much for the quick and detailed reply. A few more things.
1) What is the proper ratio for LCD ano, I'm using 20% Acid to 80% dist. water by volume as of now. Something I found on a site before I stumbled onto caswell. "ASF and desired thickness of coating dictates the time of a run. a 1 mil coating grown at a 4.5ASF has a run time of 160 minutes. ASF and size of the part determine the amount of current needed. A surface area of 81" at 4.5ASF has a current setting of 2.53 amps ASF and set up circuit resistance controls the needed voltage. With good electrical connections and a proper LCD acid ratio mix in the tank, a 4.5ASF should have a peak voltage demand of approx. 11.25V." 2) So I would set it to run at 2.53 amps for current, and 11.25volts max for 160 min according to the formula? = 1 mil 3) Is there any known problems with long runs like this? 4) Would I set the voltage at 11.25? Because I notice you said peak voltage demand or approx. 11.25V. I think this is the only part I don't quite understand at this point. Also I am looking at this power supply Amazon.com: MASTECH VARIABLE REGULATED DC POWER SUPPLY 0-30V 0-20A: Home Improvement Which I assume you can control and monitor voltage and current would this be the correct type? |
hey hoping someone who knows their stuff looks here... i have the ps found here.
http://caswellplating.com/kits/rect.htm the third one down the 25 Amp Constant Current Rectifier. just wondering... using the 720 rule calculator. i input the following; Surface area: 300 inches2 (or 2.08 ft2) Thickness: .5 mil Current Density: 6 (the calculator was preset at 6, dunno what i should put there.) then it gives me: Set Current: 12.5 Amps Time: 60 minutes Peak Voltage: 15 Vdc so what do i want to do with these now? sorry for being a nub just wanna do it right, thanx! |
Thickness: .5 mil Current Density: 6 (the calculator was preset at 6, dunno what i should put there.) then it gives me: Set Current: 12.5 Amps Time: 60 minutes Peak Voltage: 15 Vdc CD is the amount of current being run through the part per square foot. With that PS I would go to 4.5 or 5 ASF so your voltage available does not max out. Turn your PS to 15V and your amps all the way down. Make the connections and turn the PS on. Slowly adjust the amps up to the 12.5A set current and run for 60 minutes. These numbers will change with different CD's. Don't worry about peak voltage unless it is at or over your PS capabilities. SS |
First of all, you need to get your head round the idea that what you want in basic LCD process is Constant Current - and that unit looks a good one for that. Most of these modern power supplies allow you set a constant voltage or a constant current. In effect, what you're doing when you set the limit for constant current or constant voltage is saying the the supply 'pump as much as you can into the load (tank) up to the limit(s) I've set'. If you were testing some electronics on the bench, you might set it for 12v and then set a safety limit to the current of 1A. However, when we're doing constant current anodising, we want the power supply to always force the current (12.5 Amps in your case) through the tank. So ... set the current limit at 12.5A and set the voltage control to the maximum - that way it will only be the curent limit that comes into force. If a supply has an actual switch for CC/CV (Constant Current or Constant Voltage) then make sure it is in the CC position. In terms of the actual procedure, especially as the current gets higher, if you just turned it on and let the current rush in, depending on your racking arrangements, you could get contact-point burns or even blow aluminium wire away - so its always best to
The 60 minutes is the meat of the 720 rule - that is the time from when you get the current on till you turn it back down again (remember though that you shouldn't leave it in the acid after the current is turned off as the ano layer will be eaten away) The Peak voltage is just an indication. It has absolutely nothing to do with setting your power supply - it is just the peak voltage you might possibly see - its affected by the workpiece itself, temperature, acid and most especially by the type of racking (eg Ti from Servisure) you use. The peak voltage is also useful because it can help indicate the amount of heat being pumped into the tank by the anodising process. In your case you'll be heating the tank at peak at nearly 200 watts ...... I suspect that unless you've got a big tank, or lots of circulation, you may need to take steps to control the temperature. cheers / Dave EDIT ( SS - we crossed because your message was more concise than mine !) Last edited by dmiom; 01-16-2009 at 08:40 PM. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| stayhi |
| Anodizing with a rectifier | sgunn911 | Anodizing Questions | 1 | 06-24-2004 07:28 PM |
| Color depth vs. anodizing time | NeoMoses | Anodizing Questions | 17 | 02-03-2004 10:06 PM |
| Complicated things for a total anodizing newbie. | taylorm | Anodizing Questions | 2 | 01-19-2004 11:50 AM |
| Anodizing different alloys | TONYZ | Anodizing Questions | 2 | 11-02-2003 02:31 PM |
| Titanium anodizing | lorenzo | Other Metal Finishing Questions | 1 | 06-27-2003 09:56 AM |
