Old 11-28-2004, 02:20 PM
kickn
Default racking screws
Okay - Thanks so far for everyone's help - i'm up and running with the anodising and getting some pretty good results.
My most recent challenge though is with racking some screws that I need to color. I need the best possible finish on this so I'm looking for the best option here. The screws are hex head counter sunk M3 x 6mm screws. I know - they are very small but I still need a good finish.
I was going to try and buy a small bit of aluminium mesh and wrap a small bundle up in that but I wasn't sure how a) the number of contact points with a 'bundle' of parts would effect the final finish? b) how the density of the bundle would effect the anodised layer? What I mean is that would the screws in the middle of the bundle get the same result?
I don't want to have to sput weld each one and have tried tying them with small ali wire but that was very time consuming and given the softness of ali - proved inconsistent. I started trying to screw them in to a sheet of lead but I think the threads wouldn't get a very clean result.
Any thoughts for those up on a sunday night?
Old 11-28-2004, 03:10 PM
Glad to hear that you are making progress.
I still like the idea of threading the screws partially into a lead plate. The plate doesn't have to be thick, maybe 0.7 - 1 mm thick. Since they are screws, there has to be some portion of the thread that won't show. The plate is no larger than what you need for your batch of screws. Since the lead is so soft, just punching holes in the lead plate should work.
Old 11-28-2004, 05:42 PM
kickn
Okay - i'll give that a shot and also I'll try a small batch of the screws in the mesh.
cheers fibre!
Screws and small parts kickn Anodizing Questions 16 04-17-2008 01:54 PM
Quick question on "old" ano method...... Sid03 Anodizing Questions 44 05-09-2006 11:38 PM
newly chromed screws rusting c5mine Electroplating Questions 1 09-07-2003 11:53 AM
Plating automobile screws c5mine Electroplating Questions 6 08-17-2003 09:38 PM
Plating screws? chromo Electroplating Questions 2 01-21-2003 03:17 PM
