Just a quick note it's almost 10:30 PM and I just finished a test run using an aluminum bar as the cathode. I anodized two tubes and they turned out fine. I dyed them electric blue and they took the dye immediatly. I recorded all of the numbers and took many pictures. I see a great deal of benefits to this method. Fewer chemicals, less space for tanks and you reach the proper temperature faster. I will post a complete report tomorrow with pictures.
I have included pictures in my personal folder of the entire process.
I’m in the process of re-anodizing my professional lighting stands. All of them are made of aluminum but I am unsure of what type of alloy they are. The stands break down into four aluminum tubes and some straight pieces for legs. The tubes fit inside one another so they telescope out. The tubes I tested out are 23 and 24 inches in length and ½ and ¾ inches in diameter. This gave me a measurement of 92 square inches for both tubes. I used 6 amps per square foot and calculated my current density at 3.8 amps. Because of the length of the tubes I decided to try to strip, clean, de-smut, anodize, dye and seal the tubes in schedule 40 PVC pipe. I purchased one 4 inch diameter x 10 foot long PVC pipe and one 6 inch diameter x 10 foot long PVC pipe. I cut the pipes into 3 foot sections, cleaned them out and capped the ends using purple primer and PVC cement. I secured the pipes to my work table using eye hooks and bungee straps. The 6 inch diameter pipes hold a little less than four gallons each and the 4 inch diameter pipes hold a little less than 3 gallons each. I used the smaller diameter pipes for cleaning with hot SP degreaser, de-smutting, dyeing and sealing and I used the larger diameter pipes for stripping and anodizing. I proceeded normally with stripping, cleaning and de-smutting the two tubes. I used my sput welder to make aluminum wire connections to the inside of the tubes. I set up my anodizing tank differently form my normal Caswell 6 gallon anodizing tank. I was going to anodize the tubes using aluminum roofing flashing as my cathodes. Fibergeek than suggested that I use a single piece of aluminum bar stock 1/3 less the surface area of the pieces being anodized. I went with a piece of aluminum bar stock 1 ½ inch wide x 25 inches long. This gave me a surface area of 37.5 square inches a little more than a third. I later realized that I could use a much larger piece of bar stock with various square inches etched on the surface. You could than choose the surface area needed and submerge only that part of the bar stock into the tank clamping it in place with a plastic clamp. The use of bar stock as a cathode was an absolutely brilliant idea by Fibergeek. I’m hoping Fibergeek will go into detail the differences in flux patterns between a normal setup and this one. For power source connection I welded two aluminum wires to the bar stock using my sput welder. The physical differences are apparent in as much as I was able to push the tubes up close to the far wall of the tank and not have to worry about the pieces touching a cathode. Remember I only had one piece of bar stock in the tank. I will further try to determine how many pieces I can anodize in one tank and what spacing is needed between pieces. My tank temperature was between 72 and 73 degrees. I used air agitation using a Boyu S1000 air pump connected to a homemade PVC aerator sitting at the bottom of the tank. This gave me a lot of agitation with large bubbles coming up to the surface. I noticed hydrogen bubbles appearing quickly I assume because of the smaller size tank. But the agitation is much greater for that same reason. Also because of the smaller size tanks and the thickness of schedule 40 PVC pipe the tanks heated up very quickly. If you use this method you will have to monitor temperatures at all times or you will miss your mark. I walked away from the sealer tank with two heaters immersed and when I came back 10 minutes later 1/3 of the sealer had already boiled over the top of the tank. My voltage readings at a CD of 3.8 amps on my constant current power supply for this 90 minute run where 10.9 volts at the start, at 10 minutes the voltage dropped to 10.8 and stayed there until the 50 minute mark when it dropped to 10.7 Volts and finished off at the last ten minutes at 10.6 volts. Again my tank temperature was 73 F. I removed the tubes, rinsed them and dropped them into electric blue dye. They started to absorb the dye immediately. I left them in the dye tank for ten minutes and sealed them. Fibergeek and I are not sure if conventional cathode arrangement would provide the same results. I will find out when I have more time by using conventional cathodes on my next run. However I prefer this method over the conventional method The benefits of this process are smaller tanks that take up less room, fewer chemicals and the added benefit of tank temperatures coming to mark sooner. Disadvantages are the tanks cannot support themselves. You have to be careful when handling the tanks with chemicals in them especially acids. You have a greater probability of splashes and tank spills with this method. I am also not sure how the PVC cement will hold up under heat. If anybody has any thought on this please pass them along. I have included pictures in my personal folder of the entire process. |
Thanks Scocklin, very good work indeed!
To explain further: The unconventional (to us anyway) cathode arrangement is not my idea. I would credit Drew Nosti at Anodize-USA for it. There is something useful here, we need to check this out thoroughly. The user of this had BETTER take agitation requirements seriously, fortunately the shape of the "tank" will promote good agitation efficiency. Hot liquids in PVC pipe is definately a worry. PCV pipe and PVC cement are impervious to sulfuric acid in the concentration we use as electrolyte. |
Hello All!
Not to Hijack the thread, but how can you distinguish 6061 from other alloys? anyway specific? I have two step plates from a late model Kenworth semi tractor that were being tossed out at work, and are pretty large in size, maybe 12" by 24" and these have holes in them for traction, but other than that, are pretty clean and should provide a lot of surface area for a cathode. What do you folks think? Thanks in advance! Ben |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Do you have to use flash copper to plate aluminum | krsimulis | Electroplating Questions | 1 | 07-27-2004 02:32 PM |
| Cleaning Oxidized Aluminum With Sand Blasting Media? | freematt | Other Metal Finishing Questions | 2 | 02-23-2004 03:22 AM |
| Series 1100 Aluminum Wire | Fibergeek | Anodizing Questions | 2 | 01-27-2004 12:29 PM |
| HELP! White haze when degreasing polished aluminum! | davidh90046 | Metal Polishing Questions | 2 | 10-15-2002 02:19 PM |
