Old 03-05-2005, 08:22 PM
upncoming's Avatar
upncoming
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
Default ?¿tank and part size for anodizing¿?
Iv been powder coating with good results for a few months and would like to add some anodized parts to my projects. well the LCD kit comes with 5 gallon tanks that would be good for small parts but from reading around in this forum it seems the parts must be at least 2"-3" away from the plates.
so i guess one of my questions i have is mostly everything that i would want to dip is taller or wider then the tanks offered in the LCD kit. ( valve covers, intake manifolds, brake calipers ) stuff like that. So does the parts have to be totally covered in the mixes or could the dipping be complete in half's at a time?
Old 03-05-2005, 09:01 PM
mcaswell's Avatar
Caswell Inc Founder
The LCD kit will give you all the components you want. Just get a 20 gal Tote/Keeper box from KMart and use that for the tank. Make up the solution with more battery acid and distilled water.
Have A Web Site?
Old 03-05-2005, 09:07 PM
upncoming's Avatar
upncoming
i just noticed i posted this in the wrong forum.. is there a way i could put this listing in the Anodizing section....
thanks im going to go to k-mart to see if i can find what your talking about.. . when you say keeper box are you talking about a storage ben?
Old 03-05-2005, 09:24 PM
sswee's Avatar
Moderator
I am using the large clear storage bins that come with a lid. Get them alot of places and many sizes.
Old 03-08-2005, 10:05 PM
kiwijetpilot
I'm interested in this too - I am going to use 15 gal tanks, but the material seems to be an issue. I have been told that you shouldn't use polyethylene (high or low density), only polypropylene or PVC. Anyone have any comments on this?
Old 03-09-2005, 07:25 PM
M_D M_D is offline
M_D
A plastic tote will work, but since they are a bit weak for that much heavy liquid you might consider building a frame from 2x4's and plywood to reinforce it. Then you won't need to worry so much about it bowing out and breaking open. It'll still be an inexpensive tank.
Avoid nylon at all costs in the acid tank (will disolve and make a mess of your parts), but the polyethylene is fine for electrolyte.
?¿tank and part size for anodizing¿? upncoming Anodizing Questions 2 03-06-2005 10:51 PM
Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled frubino Anodizing Questions 1 07-27-2004 02:56 PM
A few question to help a beginner Cyberave68 Anodizing Questions 6 06-08-2004 09:53 PM
Anode size to part ratio mdarr Electroplating Questions 1 07-24-2003 03:20 PM
plating and size power? chromo Electroplating Questions 7 01-18-2003 03:52 AM
