Has anyone used the Sput Welders to connect the wire to the parts of a firearm that may be anodized? Is this the best possible connection for the frame of a pistol or rifle receiver? What is your experience?
Neilfj has sput welded the connection on at least two AR lowers. I have done it on two AR lowers and several aluminum pistol frames. As usual we both had excellent results and zero electrical problems.
For something the size of an AR lower (0.56 Sq.ft. surface area) I welded the anode connection (16 AWG Al wire) inside the fire contol cavity. To stabilize the lower in the tank I added a second suspension point by loosely looping a second wire through the front pivot pin lugs. This second wire has no electrical function and is only used for stability. if its loose enough it won't interfere with anodizing and dyeing. |
| Powder coating on firearms | LoneGunman | Powder Coating Questions | 2 | 06-15-2006 12:54 PM |
| type 5 sput welder? | Renegade_43 | Anodizing Questions | 0 | 06-28-2005 03:18 PM |
| sput welder | lastone75 | Anodizing Questions | 38 | 03-15-2005 09:48 PM |
| SICK OF BAD CONNECTIONS? SEE THE SPUT WELDER - NOW AVAILABLE | mcaswell | Anodizing Questions | 35 | 12-01-2004 09:59 PM |
