Using the 720 calculator provided by the friendly folks here in the forums, we have stumbled across an easy way to get surface area. I dont know if its been discussed here, but its been working great for us.
First, connect your parts to the rectifier (we use a 20amp Hyui Yi, thanks Caswell). Turn your voltage all the way up, and your amperage all the way down. This sets the rectifier to constant current mode, in its lowest setting. Wait for your voltage/amperage to level out with the parts in the bath... when they steady (seems to take about 10 - 15 seconds with my rectifier) sprint into the other room where your handy desktop PC has the 720 calculator open and ready for bid'ness.
In the bottom portion of the calculator, enter the voltage and amperage of the rectifier at its "idle" setting into the according position. Take the surface area given, enter it into the top portion. Then its back to the rectifier with your new information, set amperage accordingly, and watch the clock.
These calculations have been as, or more accurate than my sketches in solid works. I hope this helps people out, if not, and your torch your first project....![]()
LinkBack URL
About LinkBacks
