Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 04-06-2005, 01:46 PM
Default polished alum
If I polished up alum wheels to a mirror shine. Can I anodize them clear and still maintain the shine? Would I have to seal it?
Old 04-06-2005, 08:07 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Typically, anodized polished parts don't retain the full shine they had at the beginning of the process. The slight dulling effect can be minimized by anodizing for shorter times, resulting in a thinner anodized layer.
On some polished wheels, instead of anodizing, they are sealed with a clear urethane coating.
I suggest experimenting, or at least looking at some clear anodized parts for reference.
Old 04-06-2005, 08:44 PM
sswee's Avatar
Moderator
I agree with acidrain. I polish alot of parts to anodize and they loose a little shine but still look great. Not a super big difference than clear polyurathane parts I've done. Something to think about though is to anodize a 15" x 7" rim will take approx. 21 amps at a 4.5A CD.
Old 04-07-2005, 01:32 PM
Thanks guys
21Amps are no problem, I have a 150A rectifier that I use for my chrome plating. I haven't tried anodizing yet, I will practice on a few parts after I get this chrome thing down. The wheel is off a "Fatboy" which isn't really that shiny to begin with. If I polish to a mirror shine and it gets a little duller, that's cool with me. I just want to make sure it wouldn't turn out milky looking.
Old 04-07-2005, 06:22 PM
M_D M_D is offline
M_D
I don't know the maximum voltage of your rectifier or if it is constant current cabable or not, but I do know some plating rectifiers have a lower maximum voltage limit than is required by anodizing unless the current density (amps per square foot of part) is kept low.
Old 04-07-2005, 06:43 PM
sswee's Avatar
Moderator
Is that Fatboy as in MC? Depending on the style, amps needed could be a bit different. Haven't had any parts turn milky. Anodize over clearcoat any day in my book. Like M_D said, you need to check you max voltage on your rectifier and if it is constant current capable.
Old 04-08-2005, 01:43 PM
my rectifier is CC or CV but the max voltage is 5.5V, is that enough? I don't understand what MC is sswee, but the wheel is off a Harley.
  #8 (permalink)
Old 04-08-2005, 04:12 PM
M_D M_D is offline
M_D
I think you would need 10+ volts. It will vary according to conditions and current density. The is a current thread entitled "Peak Voltage ?" that may provide you with some usable information.
  #9 (permalink)
Old 04-08-2005, 07:28 PM
sswee's Avatar
Moderator
MC - motorcycle. I've a 82 XLS. Like M_D said peak voltage needed for a 3amp CD is 7.5 volts. That's about as low as you want to go and is only a calculated value. It could be +-2 volts depending on the variables
  #10 (permalink)
Old 04-09-2005, 09:27 PM
Thanks all for the help. It sounds like I would need another PS, that's getting to be way more expensive than it's worth to do one wheel. I was hoping since I have a plating setup, I could use what I already have. I can buy a chrome wheel for around $300, maybe I will go that route. Thanks again.
Closed Thread
clear coating polished alum hybred Metal Polishing Questions 7 08-08-2005 03:58 PM
powder of polished alum? hybred Powder Coating Questions 3 08-07-2005 03:38 PM
Do ALL freshly polished metals rust? kwood69 Metal Polishing Questions 4 10-27-2004 12:25 AM
How do you clean your polished aluminum? mach1man Metal Polishing Questions 3 10-02-2004 03:42 PM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 02:19 PM
