I am working on both my Ano line and an Aluminum part. The part need to have a hole plugged and to seal the plug, I generally just use Red Loctite.
I was wondering what I should expect to happen if that part goes into the ano stage ![]() Thanks, Edwin |
I am already aware the problems with wrong metals in the bath, but I want to plug this hole and seal it with Loctite, then polish, then ano. Do you have experience with this? |
I guess I was just confused. Sorry about that.
When you asked your question, I was like.....ahh....."well does it matter, as I still need to know about the loctite" I guess you were able to read that I was a bit irriatated. Thanks for your post either way. I am learning a lot just by reading your posts and others on this Forum. It is very usefull. I even calculated my first 720 rule for .7mils. It isn't bad once you put it on paper, and think through it. It does help to have the part in Solidworks as surface area is a click away. |
There is a good chance the loc-tite will insulate the plug and it won't ano.
I did a two-piece paintball barrel the other day that was factory joined in the middle. It only ano'd on the side that was connected. I had to give the customer a new barrel. |
Silicone is out, as I need the strength of loctite.
Acidrain, good point. I guess it might work as long as you ohm out the part and the plug. If they are short, then maybe it would work fine. I am still concerned if the acid bath with eat away at the loctite. I guess trial and error is in order. |
Acidrain -
Not to deviate from topic, but I too have done that before. Typically with my mistakes, its on a press fit feedneck. I find by giving the insulated part its own lead to current, Ive pretty much alleviated that problem. Buying customers after you break it... yea, we've ALL been there. |
I have to question why you need to loctite the threaded plug prior to anodizing it.
Plugs exist in many shapes, and sizes, and material types. Nylon, Plastic, Cork, Rubber. I have used them all in a commercial environment. I see no reason to loctite a plug prior to anodizing. Plug the hole, anodize the part, attach the permanent plug and loctite it in place. That eliminates the problem of the loctite causing issues (which it should not) and I think you'll be happier in the end anyway. |
| Problems using 12asf and 4.5asf! | Chevalier | Anodizing Questions | 3 | 02-04-2004 09:55 PM |
| Color depth vs. anodizing time | NeoMoses | Anodizing Questions | 17 | 02-03-2004 10:06 PM |
| Consistency Problems | NeoMoses | Anodizing Questions | 6 | 12-13-2003 04:01 PM |
| Anodizing different alloys | TONYZ | Anodizing Questions | 2 | 11-02-2003 02:31 PM |
| Does anodizing too long cause problems? | desert_roamer | Anodizing Questions | 4 | 08-06-2003 12:32 PM |
