I started off with 20oz of acid and 40oz of distilled water. (2 parts water, 1 part acid)
I am running a fairly small tank for now, I am just testing things before i end up with 5 gallons of a lethal concoction... the test pieces were only scrap pieces of stock that I cleaned up to play with. 1 ~ 2 sq inches roughly. Also I should preface this with a little history, I found a post about "home anodizing" and thought I would give it a try, only after some issues, and some follow up research did I find this site and all this great information. So I am trying to "catch up" before I go any further. So if my acid is 100% and I need it down just under 5% that means I am way rich on acid, but I am not sure if its just as simple as a straight ratio. Do I have 33% now? thanks for the help. I am reading as many posts as I can squeeze in between my real job.... and all the information I have found has been very enlightening. glad I finally found this forum. |
The wires are titanium and are for hanging your parts on. The work much better than aluminum IMO and are much more durable. The resistor is 0.1 ohm resistor and is used in conjunction with the dimmer switch to control current. The voltage drop across the resistor will be 0.1 volts for each amp of current. You simply set connect the voltmeter across the resistor and adjust the dimmer swith until you get the correct current through the resistor.
Bill |
| Acid | SniperSlayer | Anodizing Questions | 8 | 07-25-2005 10:59 PM |
| Acid copper | Gabourie | Electroplating Questions | 3 | 09-25-2004 09:42 PM |
| "Sandwiching" Acid Copper | AresP | Electroplating Questions | 1 | 08-27-2004 09:19 PM |
| Acid concentration versus current density | M_D | Anodizing Questions | 7 | 02-04-2004 10:01 PM |
| Acid Bath Content? | Chevalier | Anodizing Questions | 3 | 01-12-2004 11:46 PM |
