Old 06-18-2005, 04:38 PM
machinist_1
Default Acid
Would there be any problems with my anodizing if I was to mix my acid solution a little strong? Say, 1 gal to 1 gal. I bought my battery acid from Napa. It's a five Gal. container with Sp. GR. 1.265.
Thank you for any Info. machinist_1
Old 06-18-2005, 10:48 PM
sswee's Avatar
Moderator
Yes, you'll have dissolution problems.
Old 06-19-2005, 10:49 AM
machinist_1
I was afraid of that.
Thank You;
Old 06-19-2005, 05:57 PM
sswee's Avatar
Moderator
Just an idea. I found the cheap ($17.95) utility sink at Home Depot is made of HDPE. It is 20 gal and sturdy, will sit flat on table without the legs. All I had to do was put a 1-1/2" PVC cap on the drain. Is working good. About 21" square and 13" Dp.
Old 06-20-2005, 11:47 AM
machinist_1
Thanks For the info.
What I am using at this time is two 20 gal. water tanks from a Motor home ( RV). I use one for my Ano tank and the other is full of Acid mix also. I circulate the two together to help keep the temp down.
Another Question. What are the two pieces of wire that comes with the Ano. kit? There is resitor with the wire also.
Old 06-20-2005, 04:14 PM
sswee's Avatar
Moderator
Unless it's to hook up an ammeter, I don't know. They tell how to use a resistor in the manual.
Just some general info on acid concentration
Concentrated sulfuric acid; 100% by weight and volume.
Commercial battery acid; 35% by weight, and 19.2% by volume.
"Professional" electrolyte; 16.5% by weight, and 9.4% by volume.
Caswell's 1:2 electrolyte; 6.4% by volume.
LCD electrolyte; 4.8% by volume.
Old 06-22-2005, 08:17 AM
machinist_1
Thanks again for the Info.
  #8 (permalink)
Old 07-13-2005, 03:04 AM
jaggy13
hmmmm, I am using concentrated sulfuric acid. (purchased at a chemical supplier) I was under the impression that I would need 2:1 ratio with that. but by looking at your statement above, I would think it would need to be much, much more diluted. Sorry for the newb question, just may be the start of the problems I am having. thanks in advance.
  #9 (permalink)
Old 07-13-2005, 09:14 AM
sswee's Avatar
Moderator
For LCD anodizing you need a 3:1 ratio by volume with battery electrolyte giving a 4.8% by volume. Using too high a concentration causes dissolution and other problems.
  #10 (permalink)
Old 07-13-2005, 10:28 AM
jaggy13
so I would need to dilute mine even more? like 20:1?
Acid SniperSlayer Anodizing Questions 8 07-25-2005 09:59 PM
Acid copper Gabourie Electroplating Questions 3 09-25-2004 08:42 PM
"Sandwiching" Acid Copper AresP Electroplating Questions 1 08-27-2004 08:19 PM
Acid concentration versus current density M_D Anodizing Questions 7 02-04-2004 09:01 PM
Acid Bath Content? Chevalier Anodizing Questions 3 01-12-2004 10:46 PM
