The parts I'm making require holes to be plugged. I'm using slightly oversize aluminium plugs, press fitted to the holes. The face is milled and polished. At this stage it is impossible to see the plug. After anodising the plug becomes visible, but when dying the color wont take at the edge of the plug. (See pic).
Possible causes? 1. Metal charateristics altered by the compression effect of the interference fit of the plug. 2. Residue citting oil in the hole leaching out in the hot dye 3. Acid penetrating the seam between plug and body Anyone have more than a guess as to the cause.
| Flash Copper Problem | gwjohnso | Plating Pot Metal | 12 | 02-27-2007 11:41 PM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 05:21 PM |
| Anodizing Problem???? | Cyberave68 | Anodizing Questions | 3 | 03-31-2004 02:03 PM |
| Nitric Acid/Desmut problem....Help | Easttex | Anodizing Questions | 1 | 02-19-2004 10:59 AM |
| BEWARE!!! Problem Plating Car with Metallic color paint! | GoldiesPlating | Electroplating Questions | 0 | 08-29-2003 09:29 PM |
