Old 07-22-2005, 12:23 AM
dangerdan
Default Starting freelance anodizing
So I'm thinking about starting freelance anodizing at home. I play tournament paintball and I know people that would let me anodize for them once I got anodizing down.
So my question is, what all do I need?
I need something that works great, but doesnt cost a fortune (paintball costs enough).
Any help appriciated.
Old 07-22-2005, 12:56 AM
destroyer125's Avatar
*power source/recitifier/battery charger
*tank of some kind(rubbermaid containers work well)
*dyes
*sealers
*battery acid
*distilled water(lots)
*aluminum wire
*aluminum or lead sheet (to make cathode)
*practice and the power to go thru w/ this
caswell has everything except the acid,tank, and the last one
Old 07-22-2005, 01:25 AM
dangerdan
So how much with this probably run me?
I dont need a huge kit, just enought to get by.
Old 07-22-2005, 02:11 AM
sswee's Avatar
Moderator
Go here and read up on procedure. It will tell you how and give you an idea of the components used.
http://www.caswellplating.com/kits/lcd_ano.pdf
*power source/recitifier/battery charger - 50.00 to 300.00 depending how you go. Rectifier is the best, I've gone down that road. Caswell 3Amp 100.00.
*tank of some kind(rubbermaid containers work well) - 10.00 to 20.00 You need one big enough to hold the part and some extra room for electrolyte so you don't have hard temp. rises.
*dyes - Check Caswell site for dye. Also need bucket or container and a way to heat to 140 degrees.
*sealers - Check Caswell site for price. You can boil to seal. Also need container and way to heat to boil.
*battery acid - about 6.00 a gallon last I bought
*distilled water(lots) - 1.00 a gallon at most grocery stores
*aluminum wire - price varies on size and vendor
*aluminum or lead sheet (to make cathode) - price varies on size, grade and vendor
Alot of things will save heartache by spending a little to setup right from the git go than to save a few pennies going the cheap route. Best of luck.
SS
Old 07-25-2005, 08:37 PM
mcaswell's Avatar
Caswell Inc Founder
You can't go wrong by buying an LCD Anodizing kit.
Have A Web Site?
Old 07-27-2005, 12:12 PM
Sid03
dangerdan- he is right, buying the caswell kit is the easiest method to getting started.
And please be prepared to invest much time into learning to anodize. It isnt always as easy as buying the stuff and BAM, your a professional anodizer. There is ALOT involved in the fundamentals of anodizing, and it def. takes some time to learn the in's and out's. The book that should come with your kit will give you a great head start, and forums such as these will help with other questions.......just be prepared to invest more time into it then $
"Hard" Anodizing vs. "normal"; differenc dagobert Anodizing Questions 6 02-27-2004 12:24 AM
Color depth vs. anodizing time NeoMoses Anodizing Questions 17 02-03-2004 10:06 PM
Complicated things for a total anodizing newbie. taylorm Anodizing Questions 2 01-19-2004 11:50 AM
Anodizing different alloys TONYZ Anodizing Questions 2 11-02-2003 02:31 PM
Titanium anodizing lorenzo Other Metal Finishing Questions 1 06-27-2003 09:56 AM
