Old 08-01-2005, 03:22 AM
redback
Default commercial readily available desmut
I am removing anodise with phosphoric acid (for reasons I wont go into I cannot use lye, caustic soda)
the anodize removal works fine but it leaves the surface of the aluminium with a smut or greyish colour
is there a readily available agent I can use as a desmut
Old 08-01-2005, 06:46 PM
destroyer125's Avatar
you can buy de-smut in I think 10 gallon amounts from caswell
Old 08-01-2005, 07:03 PM
sswee's Avatar
Moderator
A quart of Caswell DeOx/DeSmut makes 2 gallons.
Old 08-02-2005, 12:35 PM
captmorgan
redback
So, you won't tell us the reasons for using phosphoric acid. Are you keeping valuable secrets from us? Must we invoke the Freedom of Information Act to learn this important information?
I have been using a lye solution as a stripper. Although it works, it can't help but dull the finish or if used too long, pit the surface. Does phosphoric acid attack the aluminum? I could use a cheap alternative to lye.
Old 08-07-2005, 01:31 PM
SniperSlayer
one way to find out where can you get ahold of this acid i've never heard of it being used before
Old 08-07-2005, 11:56 PM
sswee's Avatar
Moderator
Phosphoric acid is commonly found in a rust treatment chemical farmers have been using for years to treat their cattle trailers.
Old 08-08-2005, 02:45 PM
let us know I wanna know if this works :P
Buildup after using Desmut viper753 Other Metal Finishing Questions 3 07-03-2007 04:24 PM
Deoxidize, Desmut, etch? on polished aluminum thesmoothers Anodizing Questions 3 06-11-2006 10:28 AM
commercial platers txturbo Electroplating Questions 2 01-31-2006 01:03 PM
etch....desmut.....deoxidize.........weeeeeeeeeeeeeee Sid03 Anodizing Questions 8 02-19-2005 12:05 AM
