I have a couple of questions about the dye process.
1)What is the reason for the dye to be 140 degrees? 2) Can I just turn up the temp and boil the dye and use it to seal also(I am boiling to seal right now)? Thanks for your help! Tim |
I was wondering this to after reading the manual on page 140 on airbrushing the dye on. Now how would this be done, as you cannot airbrush in 140-degree heat.
I found the manual very informative, but I didn’t see too much in the way of applying the dyes with the different methods listed. Thanks Bill |
Our supplier specifies this heat as optimum.
NAPA acid = prod # 9002 Try any battery supplier. Sealing in the dye isn't in the procedure. You could try it - but don't complain if it doesn't work. Airbrushing will result in the possibility of a weaker color. You may need to increase the concentration to counter this.
| LCD anodize of a large piece? | scocklin | Anodizing Questions | 2 | 12-29-2004 12:21 AM |
| Sealing | RPE | Anodizing Questions | 1 | 04-08-2004 02:39 AM |
| A question for the anodize boys from the powder guy | non-stick | Anodizing Questions | 3 | 11-26-2003 04:22 PM |
| Basic anodize questions | erogers | Anodizing Questions | 0 | 03-12-2003 07:54 PM |
| Anodize sealing bath life? | desert_roamer | Anodizing Questions | 1 | 05-06-2002 05:16 PM |
