Is it practicable to use multiple GP plates on EACH Side of a part? I have to anodize a 24" long part and I would like to do it in one immersion. I currently use a pair of 8x8 GP plates (one per side). I am concerned whether the plates are big enough to anodize a 24" long part so I thought I would purchaes a couple more plates and have two per side. I am using a Cooler for a tank. Inside measurements of the cooler are 26" x 12" x 10".
Hmm. That is interesting. I called Caswell before I did some plates earlier (yes the ones I had all the trouble with) and asked if my 8 x 8 GP plates would be OK to Anodize a part that was 20 x 12 x 0.5 and they told me the plates would do that part just fine with one 8 x 8 plate on each side. So I had less than 1 sqaure foot of total plate (cathode) area to Anodize about 3.5 square feet of part (anode). I was told by them that I would be fine and that I just need to make sure I had the plates between 3 and 9 inches from the part. I had a LOT of trouble with those plates and according to this it is perfectly understandable.
OK, one more question. Does the rule work both ways or can I keep 4 plates in the tank even for smaller parts? Thanks |
We never did identify the reason for this, but we did determine that there is a relationship between the cathode size and the success rate. The closer the cathode size came to equaling the anode size, the higher the chances of a successful anodization, and once you got to a 1:1 ratio, it was a good as it was going to get. And as sswee stated, over a 1:1 ratio there would be no benefit, but it didn't hurt anything. So, to keep with the reason behind the development of LCD, we decided to recommend that the cathode at least have the same surface area as the anode. Last edited by neilfj; 12-19-2005 at 06:08 PM. Reason: Spelling |
I was talking with Mike Caswell earlier today and it reminded me that I hadn't been around in a few months. I had stopped by a few other times, just not much to say...you seem to have everything well-in-hand so there wasn't much of a need for me to add anything constructive.
| multiple colors | sswee | Powder Coating Questions | 6 | 07-27-2005 07:19 AM |
| raplacement for GP plates ? | jtagger19 | Electroplating Questions | 2 | 06-05-2005 05:49 PM |
| when doing multiple PC coats..... | strongtower | Powder Coating Questions | 4 | 05-21-2004 12:44 PM |
| GP Plates? Anodes? | Tim Wiltse | Electroplating Questions | 1 | 10-02-2002 11:30 PM |
| copper plates | dcarter | Electroplating Questions | 1 | 01-18-2002 07:58 AM |
