Originally Posted by sswee
No problem. It's hard to hear the typing on how it's meant, no offense taken. I use a 8A CD because of PS limitations. I have been told the LCD mix of 5% acid will work up to a 12A CD. After that a higher concentration is better. SS
I'm Back! [
sswee, 5% acid was successfully tested up to 24A CD with no ill effects. The main issue with higher current usage is that it requires very agressive agitation or aeration to disperse the heat and to make sure hydrogen bubbles don't cling to the workpiece. In fact, just before Paul had passed away, we had begun testing using chilling equipment to assist in the heat dissipation.
We didn't really publicize the higher current usage to any great extent as it began to push the definition of Low Current.
