Hi, I recently ran my second anno batch and ran into some problems. We ran it for about 95 minutes at 2.8 amps (should have been 3 but I remembered the number wrong) with a peak voltage of 14-15. During the 95 minutes there were never any bubbles forming on the part that we could see, and the voltage never dropped off, which is why we left it in for so long, seeing if it would ever reach PAR. After we took it out we left it in red dye at 115 degrees for 15 minutes, it didn't take any color. Now comes the strange part, just for fun I thought I would wash and dry the pieces and then test them for resistance. They all had OL...which means that there was a layer of anodize there. The only thing I can think we did wrong was that when i was trying to get the pH for the red dye right I added to much acid so had to add a lot of base, and that happened a few times so I am not sure if I could have messed up the dye like that. Though that still leaves the question of why the voltage never dropped off?
Any help would be greatly appreciated, thank you. |
I used a new CC PS that I bought. With a CD of 6. Two of the parts were threaded into the rack on both sides of a length of aluminum wire, the other two were wrapped with titanium wire. I used a multimeter to check the voltage on the wires connecting the pieces and it was the same as what the PS was putting out.
thanks for helping |
Yea, did everything exactly like instructions say, degreaser at 150 degrees for 5 minutes, rinsed and it passed water break test and then did de-oxidizer at 100 degrees for 3 minutes. Rinsed again and put in anodize. Another thing that i forgot to mention is the it has been maybe a month or two since I set up the anodize tank and haven't used it since then, I noticed that the water level had dropped so I added more water to bring it back up, does the acid evaporate too? Should I be adding more acid also?
Thanks a lot |
To late now I know, but an easy way to check if it was a dye problem would have been try another dye. You would think if it was only a dye problem that it would at least come out an off color. Looking more like a connection problem to me, you could have got some build up of anodize, but then a connection failure. In anodizing if the connection is not perfect (very good threaded, or sput welder used) more and more stress is put on in and it fails.
Are you running lead or aluminum cathodes ? Keep up updated. You didn't run the parts in a vibratory tumbler did you ? Clint |
We are using the lead cathodes that came in the LCD kit. The connections seemed to be good but that is always a possibility. We didn't have any other dyes made up, which we should have, so we couldn't try that. Nope didn't use a tumbler. Is there anything I can change or test next time? I am really stumped...
thanks |
Just quickly looking at this, the red dye MUST be at 140 f, not 115.
I am almost positive that it didn't have anything on it prior to what we did, but that is def a posibility that I had not thought of.
I thought that 140 was right but then when we were doing it I looked at the LCD manuel and it said 110 so we did that. Is 140 for all the colors? Not sure why the manuel would say something different... Thanks a lot, hopefully we can get this working soon. |
| My first ano, suggestions | Paintbalaguy | Anodizing Questions | 20 | 09-02-2005 10:27 PM |
| newbie here, looking for suggestions | ScottM67 | Metal Polishing Questions | 1 | 04-21-2004 12:32 AM |
| Problems with LCD, looking for suggestions! | Sid03 | Anodizing Questions | 5 | 01-16-2004 04:52 AM |
