  #11 (permalink)
Old 02-16-2006, 10:49 PM
sswee's Avatar
Moderator
Default Re: white crystal salty looking stuff
Originally Posted by quadster
Tha ratio is 50/50 battery acid water. Add water when it gets low.They were probably cheap zip ties. Ill do another run this weekend.Everything last weekend came out fine after i cleaned and tightened things up.
Scott
What CD are you using? If your using the LCD method, your acid is way too hot. Your at about a 17% acid concentration instead of 5%. It's no surprise if your having problems with oxidation.
SS
  #12 (permalink)
Old 02-21-2006, 09:49 PM
mcaswell's Avatar
Caswell Inc Founder
Acidrain mentioned special chemical resistant epoxies. The are of the Phenol Novolac type. Our Caswell GAS TANK SEALER is one!
Have A Web Site?
white dye deepanod Anodizing Questions 4 03-28-2005 05:48 PM
WHITE COMPOUND IS MAKING PART DULLER THAN THE BLACK HELP.... 03BUSABOY Metal Polishing Questions 2 02-06-2005 01:46 PM
problems polishing aluminium alloy with white compound rotorman Metal Polishing Questions 6 08-02-2004 01:57 PM
Brown & White don't work kenykirschstein Metal Polishing Questions 7 04-08-2004 03:07 AM
White Compound Turns Black? GrillMan Other Metal Finishing Questions 2 08-23-2003 03:12 AM
