Old 02-04-2006, 09:35 PM
quadster is an unknown quantity at this point
Default white crystal salty looking stuff
Im using a 10 gallon cooler with a sheet of aluminum running down one side ,across the bottom and up the other side. The cathode sheet is forming a salt like substance on both sides out of the solution.Question is Is this normal?Should it be scraped off? Cleaned?Also there is black flake looking things floating and on the bottom? Does it affect the anodizing?
Thanks
Scott
Old 02-04-2006, 10:01 PM
sswee's Avatar
Moderator
Default Re: white crystal salty looking stuff
The white substance on the aluminum above the solution is oxidation. It's aluminum's equivalent to rust on steel. You can just wipe it off with a damp rag. The black flake is usually just trash. It normally has no effect on anodizing. SS
Old 02-05-2006, 01:18 AM
Go with lead sheet if it really bothers you.
Eventually you will lose the connection to the aluminum cathode, but lead will last a really long time.
Old 02-11-2006, 09:51 PM
neilfj
Actually, in reality it is a combination both salts and oxidation. The salts grow quickly I'm not sure if they are aluminum salts or sulfuric salts, but they have a definate crystal structure and for me, tend to grow thickest around the connection point to the plates. If it washes off easily, its salts. If it doesn't wash off, its corrosion/oxidation. In either case, you have to clean it off before you use the cathodes again. Both the oxidation and salts will block the conductivity of your cathodes in addition begin to effect the electrical connection, both of which will eventually impact your anodizing.
As mentioned, the quickest way to eliminate this is to replace your aluminum cathode with lead, which require much less cleaning and maintenance. Caswell has anodizing plates available.
Old 02-15-2006, 01:29 AM
Thanks for the great info. Cleaned the alum sheet. Wiped off pretty easy. Also i had four aluminum rivits (i think alum) in the bottom...only one was left? The plastic zip ties that were holding air lines broke also after about the 6th or 7th run....?
Again thanks
Scott
Old 02-15-2006, 10:46 PM
kmbrly is on a distinguished road
What is the acid:water ratio of your electrolyte?
Kimberly
Old 02-15-2006, 10:50 PM
sswee's Avatar
Moderator
Kimberly
Who are you asking?
SS
  #8 (permalink)
Old 02-16-2006, 01:50 PM
I was asking Scott because he mentioned that stuff was breaking and disappearing in his tank.
Kimberly
  #9 (permalink)
Old 02-16-2006, 02:30 PM
Some plastics don't do well in the tank...
CPVC gets a oily sticky surface.
Nylon gets brittle and cracks.
Some epoxies get milky and brittle (although there are epoxies specifically made to be acid resistant).
Polypropylene does well, and so does PVC.
  #10 (permalink)
Old 02-16-2006, 07:47 PM
Tha ratio is 50/50 battery acid water. Add water when it gets low.They were probably cheap zip ties. Ill do another run this weekend.Everything last weekend came out fine after i cleaned and tightened things up.
Scott
white dye deepanod Anodizing Questions 4 03-28-2005 04:48 PM
WHITE COMPOUND IS MAKING PART DULLER THAN THE BLACK HELP.... 03BUSABOY Metal Polishing Questions 2 02-06-2005 12:46 PM
problems polishing aluminium alloy with white compound rotorman Metal Polishing Questions 6 08-02-2004 12:57 PM
Brown & White don't work kenykirschstein Metal Polishing Questions 7 04-08-2004 02:07 AM
White Compound Turns Black? GrillMan Other Metal Finishing Questions 2 08-23-2003 02:12 AM
