+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: Spring/ Bottled water?
  1. #1
    Default Spring/ Bottled water?
    My R/O filter has been working very slow, and I was wondering if the bottled spring water like poland springs was safe to use. Given the fact that that it does not say explitly "Distilled water"
    Thanks.
    Share with Facebook
  2. #2
    Join Date
    Feb 2005
    Location
    belleville michigan
    Posts
    635
    Default Re: Spring/ Bottled water?
    most grocery stores sell gallon jugs of steam distilled water fairly cheap. it should cost a good bit less than the small bottles.
    Share with Facebook
  3. #3
    Well, the thing is, none of the bottles say "distilled" or Steam Distilled" so I'm not sure if plain "spring water" is treated and safe to use for annodizing...
    Share with Facebook
  4. #4
    Join Date
    Feb 2005
    Location
    belleville michigan
    Posts
    635
    i would venture to say no in this case. most spring water still contains mineral traces that might damage the ano process. but then again my knowledge of ano is very limited. i would wait for one of the ano experts or caswell to chime in on this before using it.
    Share with Facebook
  5. #5
    I also would say no...
    Share with Facebook
  6. #6
    Join Date
    Jan 2001
    Location
    Lyons NY USA
    Posts
    472
    Do NOT use spring water or mineral water.
    Walmart sells RO water in 5 gallon refillable jugs pretty cheap.
    If your RO is running slow, it's probably time for a filter change - and don't forget to flush the membrane for 30 seconds each week.
    Lance Caswell
    Have A Web Site?
    Share with Facebook
  7. #7
    I would sure hope it's not time for a filter change, seeing as it's brand new...
    It's been running for 4 days, producing about 1 gallon of water from 50 gallon of waste water
    Share with Facebook
  8. #8
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,283
    What do you mean by waste water?
    SS
    Share with Facebook
  9. #9
    The non purified water comming out of the orange tubing. Kent Marine calls it " waste water. I'm figuring that the the low output is due to that fact that is running at about 50 degrees.
    Share with Facebook
  10. #10
    Join Date
    Nov 2004
    Location
    Posts
    1,283
    I haven't had any problems due to temperature. I had low output on mine due to holding tank position and hose routing, causing an air block.
    Where I'm at waste water is used water. Gray water from the sinks and tubs and brown water from the toilets. I could see that stopping up your filters in a few days. LOL
    SS
    Share with Facebook
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Thread Information
Users Browsing this Thread
  1. Distilled Water?
    By machinist_1 in forum Anodizing Questions
    Last Post: 06-08-2005, 07:23 PM
  2. Distilled Water vs DI Water
    By mcgoo49 in forum Other Metal Finishing Questions
    Last Post: 03-02-2004, 08:20 PM
  3. RODI water storage
    By Easttex in forum Anodizing Questions
    Last Post: 12-01-2003, 01:20 AM
  4. distilled water??
    By scopenut in forum Electroplating Questions
    Last Post: 06-08-2003, 10:24 PM
  5. water from dehumidifier for anodizing
    By tool_man in forum Other Metal Finishing Questions
    Last Post: 02-15-2003, 03:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
