Are you asking this question as it pertains to your needs? --- I am thinking of
the message you posted requesting an anodizer in Jersey for your Rod and cooler racks. Or have you considered learning how anodizing works with small stuff and then going up in capacity as you gain experience . . . . . Because you are interested in the LCD system and its applicable, common sense approach to successful results from the many posts already established in this forum. archi |
That is what I was kicking around in my head.There's a lot of fab work on the smaller pieces.I figured if I learned the process, I could anodize parts then weld.Then hopefully down the road, increase the size of the system to be able to anodize after welding.It is however just a thought for now,cause I have some serious issues regarding space.
Jeff,
My FYI: Welding Aluminum (6061 of course--- I hope) and THEN anodizing will offer another array of qualitative issues. The AL filler rod ain't gonna look like the 6061 substrate after its all said and done. Even the LCD system and its master practicioners won't get uniform results. Ask the guys here ---- they will be the best resources to benchmark your expectations. archi |
I can verify what archi said. It can show up in several different ways and can be attributed as much or more to the heating aspect as the slight alloy difference. Not being familiar with your parts, their size or use, have you considered PC as an alternative. I am not trying to dissuade you from anodize but if the parts get too large in surface area it might be a better, more cost effective option to consider.
SS |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 07:37 PM |
| How big can I powdercoat? Having trouble | gtabadboy | Powder Coating Questions | 6 | 09-19-2005 01:02 AM |
| worth it to create an oven big enough for a car? | yerry503 | Powder Coating Questions | 6 | 08-19-2005 10:49 AM |
