Old 03-24-2006, 06:17 PM
kyo kyo is offline
kyo
Default Stripping anodizing
Ok, I know I can strip anodizing using various methods and solutions.. my question is if there is a way to mask the parts you don't wish to be stripped?
Sorry if this has been ask before, but I couldn't find any topics on it.
Thanks,
Kyle
Old 03-24-2006, 09:49 PM
sswee's Avatar
Moderator
Default Re: Stripping anodizing
Caswell sells a product called Mask-it that you can brush on.
http://www.caswellplating.com/kits/maskit.htm
SS
Old 03-26-2006, 05:54 PM
kyo kyo is offline
kyo
instead of making a new thread I'll just add to this one..
What about using sandblasting to remove the anodizing? I know it can be done, but how much power is required? Would the 'pencil blasting' units caswell sells work, or do I need something with more power behind it?
I'm not particularly concerned about it being slow in removing it, as long as it won't take me hours to get anywhere at all.
Also, I know I can easily mask the sandblasting area.. but will it leave me clean lines, or will the anodizing chip or flake?
Thanks for your help,
Kyle
Old 03-26-2006, 08:53 PM
sswee's Avatar
Moderator
I use glass bead to remove anodize all the time. If you have the air pressure and volume it shouldn't take long to remove. The lines it will leave will depend on the masking job and the direction of the blasting.
SS
Old 03-26-2006, 09:33 PM
kyo kyo is offline
kyo
any suggestions on airflow/pressure requirements?
The pencil blaster caswell sells shows 1.5cfm at 80psi.. but that seems low to me.. I'm assuming I could use more pressure with the same setup?
I'm not doing a ton of work like this, so I hate to spend a ton to get it set up. (I already have a suitable compressor..)
Assuming it is well mask and I'm careful about blast direction.. will the anodizing remaining be prone to chipping? I would think not, but I've never taken it off, just put it on.
Kyle
Old 03-26-2006, 09:59 PM
sswee's Avatar
Moderator
I was referring more to the compressor cfm. If your doing smaller parts, a bench type blaster will work fine. Using glass bead 50 to 60 psi works good. If you go with the higher pressure it comes off good but leaves the surface too textured for anodizing without etching and can embed media into the substrate. Anodize doesn't chip or peel like other coatings.
SS
Old 03-26-2006, 10:28 PM
kyo kyo is offline
kyo
ah, ok.. my compressor is capable of 7cfm, I should be fine.
thanks for all of your help
  #8 (permalink)
Old 03-26-2006, 11:09 PM
sswee's Avatar
Moderator
Any time.
SS
stripping anodizing off aluminum broker1234 Metal Polishing Questions 1 01-16-2005 09:28 PM
Color depth vs. anodizing time NeoMoses Anodizing Questions 17 02-03-2004 09:06 PM
Stripping anodizing will increase dimensions? 00_buckshot Anodizing Questions 4 12-13-2003 06:04 PM
Anodizing different alloys TONYZ Anodizing Questions 2 11-02-2003 01:31 PM
anodizing stripping neil Anodizing Questions 3 10-04-2003 10:36 AM
