Congratulations!
The one part (maybe a paintball gun item?) looks very trick. Those fades look very nice. I will answer your Ti wire needs: Look up Titanium Joe on the internet. Joe has plenty of Titanium welding wire he can send you. He has .062 I know, because I just purchased some. He also has smaller diameters, so just inquire. archi |
The parts can sit a week or two without oxidizing much. The way I do parts like that is to clean, strip and buff out, then degrease and clean just before the run. If you buff out a part to a high shine, degrease and clean to pass a water break test, you can skip the deox step. The deox/desmut is for taking off natural oxidation and smut problematic materials. If the part is fresh machined or polished, it is usually unnecessary.
The higher CD's or a sudden surge in current will definitely test your connections. If ramping the current causes you to loose connection, then you don't have enough spring tension on the connections. I would try going to a 12g or 14g wire if it will work on your parts. It will carry current better, give you more contact surface to the part and hopefully much more spring tension to hold the part and connection. If you have a good connection to the part, the agitation should not effect it. When I do smaller parts, they dance in the flow of electrolyte. Did you find out the main cause or causes to your problems or did you change too many things at once to know which had what effect? SS |
haha, well initially I got the book from Ron Newman. I used a mix of suggestions between Caswell's suggested and his.
Simply downgrading my tank to a 5gal tank and following the Caswell instructions made the difference. I did loose my connections on all my parts so far after 45min but thats due to me ramping up slightly the amps due to the amps dropping off slightly after time. Again, ill try the suggested 6ASF and not 9 till I get a better rack and more Ti wire. So far, looks like nothing detrmintal has occured from me 1/2 my anodizing time, took the colours and wont rub off (tried after 24h). Ill check out that wire online store, hopefully they ship to Canada. |
Sounds like you got it lined out. I went through the same thing at the beginning. I found 3 or 4 instructions on how to and had to figure out which one was the best. It's not easy when you have conflicting information. Keep us up on how it goes.
SS |
| Chrome and Nickel Removal Question (long) | bentley86 | Electroplating Questions | 5 | 03-19-2006 05:32 PM |
| How to polish small parts? | msmith40 | Metal Polishing Questions | 2 | 03-03-2006 08:33 AM |
| 7000 series parts dye, but 6000 series won't | acidrain | Anodizing Questions | 20 | 11-17-2005 11:19 PM |
| Copy Chrome on engine parts and plastic, alot of can I's | cgworth | Copy Chrome Kit Customers Only | 3 | 08-29-2005 01:38 PM |
| Help cleaning just polished parts | bonesaz | Metal Polishing Questions | 3 | 10-12-2004 07:58 PM |
