That looks like an applied finish to a cast part. Those types of finishes can be found at metal craft suppliers like http://www.epi.com/metalantiquing/quote-request.html and http://www.caswellplating.com/kits/metal.htm
It may be anodized first, then the finish applied. As for other types of special ano finishes, those are hard earned secrets that few will give up easily.
Specializing in anodized graphics in Paintball guns. Last edited by lcaswell; 04-05-2006 at 10:19 PM. |
Thank you for the response. I wasn't asking to show me how to do it, but where I might see more and also source it. I would like to get something simular done. As well as learn more as to what is possible.
The part is forged. I checked out the finish site you linked, but couldn't find anything for aluminum. Any other ideas? Last edited by FireBiz; 04-05-2006 at 07:17 PM. |
I'm searching for new and different finishing looks/appearance and techniques. I came across a web site that sells the "forged anodized tiles" you can see at http://www.vandykes.com/subcategory/37/ scroll down and you will see a number of samples.
I agree with them not looking anodized... but as I am not totally familiar with the process I though I would ask the people who know. Yes this or can be the parts subjected to the high temperatures. In the case of the tiles the temp range would be more like the 450 to 500 F range. An additional question, would high temp clear coating the anodized material help with dealing with the temp range I'm working with. I guess for the most part I will have to do some experimenting. Regards |
The base colors are not hard to do. The shading part is the catch. I have only gotten that look in wood staining. It has to be something in the dye consistency and/or technique being used.
There are three types of anodize on aluminum Type I Chromic acid anodize. Usually used to protect the substrate as a primer under other coatings. It is not done by many due to the type of acid used. I have only read about it and have no first hand knowledge. Type II Sulfuric acid anodize. Most widely done. Good dye qualities and protection a the substrate. Will not hold up to highly acidic or base chemicals. Type III Hard anodize. Not dyed or limited colors due to pore size. Done at higher currents and low temperature. I am not familiar with any clear coat that can handle that kind of heat. I don't see a benefit to the anodize if they have one but that is just my opinion. SS |
| "Hard" Anodizing vs. "normal"; differenc | dagobert | Anodizing Questions | 6 | 02-27-2004 12:24 AM |
