Old 04-06-2006, 02:42 PM
kumaichi
Default How do you use the CL-650 Chiller?
Hi,
I purchased the Anodizing kit last year and with summer coming I'm getting tired of using the ice cube method to cool my acid. So, I went to Caswells site and saw they sell a chiller unit, the CL-650.
My question is, how do you plumb it into my anodizing solution? Does anyone have any pictures of how to make this happen? I would like to get this ordered and working as soon as possible so any feedback would be great.
Thanks in advance,
Craig
Old 04-06-2006, 09:42 PM
sswee's Avatar
Moderator
Default Re: How do you use the CL-650 Chiller?
I couldn't find and have not seen the chiller your talking about. The chiller I am waiting on and all the ones I checked into required a pump to circulate the electrolyte through the chiller unit. Right now I am only running a magnetic drive acid pump for agitation in my tank. You can look in my album to see how I have mine plumbed. When my chiller gets here I will have to re plumb. Where the output of the pump goes up and into the tank I will have to cut and reroute through the chiller unit.
http://forum.caswellplating.com/phot...ry.php/cat/510
Old 04-06-2006, 10:42 PM
kumaichi
Thanks for the quick response sswee. The chiller I'm looking at is on the Caswell site: http://www.caswellplating.com/kits/heatchill.html From what you said, it looks like I would need an external pump to circulate the acid.
Your setup is very cool, thanks for directing me to the pictures. If I'm looking at the pictures correctly, it looks like there is a drain at the bottom of your tank that feeds the inlet of the pump. Then, the outlet of the pump goes through the pvc pipe back into the tank and is dispersed through small holes in the pvc. Is that correct?
I would be interested in purchasing the pump that you have, can you direct me to where you purchased it? Also, do you worry about the acid eating the pvc pipe and causing leaks? I would hate to have 20 gallons of acid all over my garage floor .
Thanks again for your help with this,
Craig
Old 04-06-2006, 11:31 PM
sswee's Avatar
Moderator
Thanks for the link. I looked all over and never could find it. It's about the same size unit I ordered.
The tank is a $20 utility sink from HD made of HDPE. It's approx. 21" square, 12" deep, 20 gallon. You have the plumbing right. The 2 pipes running out of the fluid on top are used to feed the pipes on opposite sides and suspend the setup in the middle of the tank. I think Little giant has a CRC (chemical resistance chart) on the site that you can download in PDF. It rates how common materials used are effected in different chemicals. If you can't find it, I can email you a copy I got from them. PVC handles the acid with no problem
Little Giant pumps - look at the magnetic drive pumps, they have 3 grades of pumps for corrosives (MC, CS and HC) I use the 3-MD-HC on mine. A little over-kill with the HC for a 5% acid but I felt better safe than sorry. Best thing is agitation without the mist from aeration. It also cools the parts better with the extra flow.
http://www.lgpc.com/
Any questions on my setup, feel free to ask. I'm waiting on the parts to upgrade to a 60 gal setup.
SS
Old 04-07-2006, 10:48 AM
lcaswell's Avatar
Caswell Inc President
That page shouldn't be there - we haven't sold that unit for years, and it's no longer being made.
You can buy a chiller from http://www.pacificcoastimports.com/
Lance Caswell
Have A Web Site?
Old 04-07-2006, 11:48 AM
Sid03
I once was going to go this route as well. The main things I didnt like was adding a bulkhead to my tank and the idea of something starting to leak and the pressure of the pump spraying acid everywhere. I have a totally different approach to the cooling situation but havnt gotten a chance to give it a shot yet.
Old 04-07-2006, 12:48 PM
destroyer125's Avatar
For a small ~10 gallon setup, whats the smallest chiller and pump I would need?
  #8 (permalink)
Old 04-07-2006, 09:32 PM
sswee's Avatar
Moderator
The smallest chiller I found was a 1/4 HP. The pump I am running on my 20 gal is a 3-MD-HC. It flows 720 GPH and does real well.
SS
  #9 (permalink)
Old 04-11-2006, 12:26 AM
sswee's Avatar
Moderator
This link is to a company that sells to distributors only. Below is a copy of the email I received from my inquiry.
We sell through distributors.
Try www.customaquatics.com
Tim Zettlemoyer
Pacific Coast Imports Inc,
PO Box 378
8225 Vera Lane NE
Woodburn, OR. 97071
503-982-6700
503-982-0760 (fax)
Tim@pacificcoastimports.com
Another link to chillers from Fibergeek is
http://www.aquastealth.com/index.asp...S&Category=243
This is also where I ordered mine.
SS
