Hi Cameraman,
I used Rite dye for my first two tries, as I could just drive to store and purchase. Set up small test tank 1/2 gal, battery charger and rite dye. After getting some reasonable results I purchased Caswell dye and a c/c - c/v power supply. Jim |
Your tank concentration is off, and can't really be controlled with a hydrometer. A method called titration can tell you your acid and aluminum content, but really isn't necessary... just go with 1:3 battery acid/water, and make a mark inside your tank (a scratch mark works good) so that additional water can be added as evaporation happens.
At the correct acid/water concentration, at 6A/sq.ft. CD, 68F, 6061 alloy, good adjitation, your volts should be in the 11v to 13v. range.
"One of my problems is too much information from too many different sources"
Doesn't this say it all? Thats why I have been a stickler for trying to get our customers to follow ONE system, the LCS system,. It's proven time and time again to work. Don't add 'other stuff' to it. All you need to know is here!
| Low temp powders? | cordcutter | Powder Coating Questions | 3 | 04-05-2006 01:37 AM |
| CopyCad & Zinc failure - electrolyte problems? | seanc | Electroplating Questions | 4 | 11-08-2004 10:16 AM |
| Voltage movement | PeterM | Anodizing Questions | 2 | 10-13-2004 05:47 AM |
| Peak voltage question | mudwhump | Anodizing Questions | 6 | 01-14-2004 11:53 PM |
