+ Reply to Thread
Results 1 to 5 of 5
Thread: Area question
  1. #1
    Join Date
    Feb 2006
    Posts
    114
    Default Area question
    I am new to anodizing. I ordered some "pinch" racks and I am putting several different size parts on them. My question is what is the best way to figure out my area to apply the 720 rule. Example, the plate is 6" X 4" it may have 10 #2 screws, 2 hollow tubes 1/2 X 2 and several other parts of different sizes and shapes?
    Share with Facebook
  2. #2
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,282
    Default Re: Area question
    It's best to be as close as possible but if your off 10 to 20%, it will not wreck everything.
    6" x 4" = 24"sq. x 2 sides = 48"
    1/2" x 2" tube = Pi x .5 = 1.57" x 2" = 3.14" x 2 (ID & OD) = 6.28" x 2pc = 12.56"
    48" + 12.56" = 60.56" SA
    This is rough since I don't know the thickness of the plate, wall thickness of the tubes, the length of the #2 screws or is it threaded holes for #2 screws. If you need help on how to figure SA, just let me know.
    SS
    Share with Facebook
  3. #3
    Join Date
    Feb 2006
    Posts
    114
    I have also had someone tell me if I lay all the parts out on 1" grids this would be close enough. Is this true?
    Also is there any benefit to a thicker anodize coating .001-.005?
    Share with Facebook
  4. #4
    Where did you get your racks from? Do you have any pictures? Would you mind telling me the cost.
    Thanks
    Share with Facebook
  5. #5
    Join Date
    Nov 2004
    Location
    Posts
    1,282
    I can see where a simpler part could be done on grid paper but most the parts I have done with the amount of complexity as your sprocket mount I have had to sit down with a pad and pencil to trig the majority of it out to get a rough SA.
    As far as dyeing there is no benefit for the thicker coating. As for durability, it will depend on how it is grown. I run at the bottom of the range on my tank temp and higher in the CD range to get a smaller pore size. I normally don't go past 1 to 1.2 mil on the coating.
    SS
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Anodizing without knowing surface area?
    By sbpoole in forum Anodizing Questions
    Last Post: 01-06-2005, 07:09 PM
  2. Need help on what area to calculate to determine my amperage
    By krsimulis in forum Electroplating Questions
    Last Post: 06-12-2004, 03:02 PM
  3. work area vs. cathode area
    By elton10 in forum Anodizing Questions
    Last Post: 03-25-2004, 09:59 PM
  4. ANOTHER QUESTION......P/C AREA
    By csaddler in forum Powder Coating Questions
    Last Post: 02-10-2004, 06:49 PM
  5. Surface Area vs. Current
    By shorton in forum Electroplating Questions
    Last Post: 11-06-2002, 11:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
