Im just wondering if anyone can tell me if its possible to use aquarium type pumps to circulate the acid in a small anodise tank or would the acid just dissolve the pump blades? or should i just use the air agitation pumps?
Also how much air agitation does anodising need is it fast injection of bubbles or just a trickle of air? . I have a small compressor that could be regulated to any psi setting so if anyone could recommend a typical pressure etc.
Any info would be gratefully received
Best Regards to all
Richard..
LinkBack URL
About LinkBacks
