Old 04-18-2006, 10:54 PM
anodizeme4ever is on a distinguished road
Post Rectifier Voltage
We are in the process of having a rectifier built to accomodate future plans. Wanted to know if anyone has any experience with these - looking at having a 200 - 300 amp built and want to know if the voltage needs to be any higher than 30 volts for anodizing.
Old 04-19-2006, 01:10 AM
sswee's Avatar
Moderator
Default Re: Rectifier Voltage
I'd be happy to find one that would do 50 or 100 amps CC that wouldn't break my bank. 30V should handle up to a 12 ASF. It all depends on if you will want to get into the higher CD's.
SS
Old 04-19-2006, 12:19 PM
So, would you go higher on the voltage to do say 3000 sq. inches?
Old 04-19-2006, 08:55 PM
sswee's Avatar
Moderator
The voltage needed depends on the current densities you are going to run. Running a 3000" SA at a 4.5A CD calculates to a 93.75A setting with a peak voltage of 11.25V . If you are runniing LCD, then 30V will work.
SS
Old 04-21-2006, 09:06 PM
What is your formula for calculating this?
Also, I want to increase current to 12 amps/sq ft
Old 04-22-2006, 12:55 AM
sswee's Avatar
Moderator
All my calculations are from the 720 rule and the results from Fibergeeks tests where he compared CD's, material types and other parameters. He measured the coating thicknesses with a current eddy meter to help verify his results.
If you plan on going to 12ASF, which is the highest with a 1:3 acid ratio, then I would try to go to a 40V supply. The calculation for peak voltage is CD x 2.5 . This is effected by several parameters and with an accurate SA will vary +-5V and I would add a extra 5V for possible miscalculation of SA.
SS
Old 04-22-2006, 09:17 AM
Cool Re: Rectifier Voltage
So if I were to maintain a maximum current of 6 amps, would a 0-15 volt, 185 amp CC/CV rectifier do the job?
Where can I find Fibergeeks tests?
Thanks again.
  #8 (permalink)
Old 04-22-2006, 01:43 PM
sswee's Avatar
Moderator
0-15V will work, 0-18V would be better. Running that many amps in a tank will generate some heat, how are you planning to maintain the tank temp.?
I was lucky enough to start anodizing before Fibergeek passed away and talked to him on the forum quite a bit. His test results are scattered in the forum posts. You can run a search on posts by him to find the info he posted. I don't have a place where all the results are together.
These are his test graphs:
http://forum.caswellplating.com/phot...user/5846/sl/f
SS
  #9 (permalink)
Old 04-23-2006, 12:47 PM
Going to have a 75 gallon rectangular tank inside a 140 gallon rectangular tank with ice water circulating around it. I have tried several methods and feel this is the best - works out to almost the same ratio of water to cool the anodizing. Also going with circulating pump for the acid to keep heat off parts.
  #10 (permalink)
Old 04-23-2006, 01:35 PM
sswee's Avatar
Moderator
I'm setting up a 60 gal tank now. I decided to go with a chiller unit. Let me know how it works. The pump for agitation will help alot. I've been using a pump for awhile. I like it much better than aeration.
SS
CopyCad & Zinc failure - electrolyte problems? seanc Electroplating Questions 4 11-08-2004 09:16 AM
Voltage movement PeterM Anodizing Questions 2 10-13-2004 04:47 AM
CC Rectifier PeterM Anodizing Questions 3 09-23-2004 06:09 AM
Sytron Rectifier Questions Easttex Anodizing Questions 1 02-25-2004 09:46 PM
[b]Epsco 3 AMP Rectifier and Copy Chrome[/b] gwjohnso Electroplating Questions 1 03-08-2003 10:11 AM
