6AL-4V ELI 0.0620" diameter
the spring tension on these are amazing to say the least, I bought $60 worth from http://titaniumjoe.com/6al-4v%20round%20bars.htm The are a V shape and the ends come out at a right andgle very short ends I will try to snap a pic I have about 40 cent each in them, make 5 from one stick, they are about 4" long when in the V shape spring, about 4" wide at the base and will be compressed to less than an inch, talk about spring tension, from my dealing with aluminum this stuff is 1000% better for making spring type connections, and cheap from the other places I have seen as well. I wil get a picture soon |
Greetings rclint,
Titanium is way cool stuff! I have also made some Ti fingers for my parts. From your description yours are very efficient. Would like to see your photos if possible. I don't know how the photos work in this forum . . . . . I would post, but I don't know if it I do it here, locally or in the Anodizing pictures thread . . . . . ? Let me know how you post your pics, if you don't mind. thanks, archi |
Below the typing box click the go andvanced tab, sroll down and you will see a manage attachments button below the submit reply, preview post buttons. You can choose the browse buttons to upload from your computer or the upload url file from a hosted website
Hope this helps, Clint |
Just done a 30 part run 100% perfect. that's the best I have ever done on these parts, I'm starting to think Titanium is by far the way to go, these small parts normaly kill me on rack time and then I always have several to fail.
More clips will be made for sure !! Clint |
clint,
Congrats on your results. And thanks for your pics--- I had a feeling your springs would be similiar in mechanics to mine. I am posting a pic of mine in the construction phase thru finish phase. thanks again for your help, archi |
thanx for your compliment,
these are some of titanium fingers used in my anodizing process. I use an aluminum "drawbar" to pull the solid ball upward, expanding the fingers and gripping the ID of the part. the beauty of titanium is its ability to spring to great dimensions w/o undo affect. for instance the nominal dimension on the finger is 5/8, but i have been able to grip ID's of almost 1 1/8" and the fingers still spring back to 5/8 when released. the picture you see is a trilogy of the start to finish using 3 fingers in different states of the machining process. below is a photo of the fingers installed on my ano rail. but i also like Rclint's titanium wire finger as well -- as we have enjoyed success using titanium in our own forms. |
| Titanium Wire For Anodes | kingkat | Electroplating Questions | 1 | 02-20-2006 09:21 AM |
| Titanium wire spring clips | rclint | Anodizing Questions | 11 | 11-12-2005 06:32 AM |
| Precision Wire Placement with a CDW | Fibergeek | Anodizing Questions | 4 | 11-25-2004 10:07 PM |
