Some parts i did last night(only took about 6 beers).Ran 5 pieces the same size 1/4 x 1 1/2 x 9 1/2 and a shifter off a suzuki(about the same size. cast).Been using a 225 amp charger with a dimmer.1 - 3 acid ratio,15 gal tank.Set it to about 16.6 volts which put the amps at about 10 and ran for 90 minutes.Dried with compressed air and masked with 3m plastic tape that i got at an auto paint store.Worked pretty good,stayed on ,didnt leech under and peeled easy when done.
Wish i could get the pics bigger,they look better.The black and silver i anodized,compressed air dried then masked and dyed black. The orange one was totally dyed orange, dried then masked then dyed black. Today i tried some elmers rubber cement but it was too thick to work with.Anyone know something a little thinner or what to thin the Elmers with?
Thanks Scott |
You can thin the rubber cement with lacquer thinner... I thin it down about 50%, but it may take a couple coats of this material.
Usually, what I do is seal for about 10min., then pull and rinse, and wipe the goo off with lacquer thinner, then seal for 20 minutes to finish. The lacquer thinner does not affect the ano or dye what-so-ever.
I did get some sticky res. and i think i laquer thinner it before sealing.Seemed to seal ok. Was one spot where the masking wasnt pressed down tight enough and it left like a spot kinda like a finger print.
Has anyone every tried to do ano flames with like a fade process?Sorry for changing the topic! Scott |
| Masking products? | SX Paintball | Anodizing Questions | 4 | 02-14-2007 12:59 AM |
| Is thin sheet acrylic ok for masking? | ld2222 | Electroplating Questions | 1 | 12-15-2004 10:29 PM |
| Looking for a MASKING product for blasting ops | Halliwell1 | Other Metal Finishing Questions | 3 | 04-21-2004 07:23 PM |
| Masking products for EN plating? | edclark | Electroplating Questions | 0 | 12-23-2003 03:41 PM |
| Looking for masking tape recomendations. | chcarver | Metal Polishing Questions | 0 | 03-06-2003 02:51 PM |
