currently I run all my dyes at room temperature and havent had a prob til now
Also a correction I have green dye SNG (the irish lookin one) not the AEN and fast Blue Last edited by destroyer125; 04-22-2006 at 02:05 AM. |
It's a good possibility that could cause some problems. When you mixed the dye, did you heat your distilled water to 180*(I think is what it says,I'd have to check) and add the dye to make sure it dissolved good.
I have always heated my dyes to 140* and not had any problems as long as the coating was right. SS |
You absolutly have to heat your dyes to 140F... both for good penetration, and to fully disolve into the water.
I have tried a couple glass fish heaters(after taking apart and removing the thermo). They work good but they break easy,especially with radical temp changes.For 13$ apiece, the caswell 300watt were the better deal.I'll be getting a couple more!
No, the fish tank heaters don't get hot enough. The cheap and easy is either Caswell 300W heater and thermostat (best) or a large stainless stew pot from the dollar store and a cheap hot plate (will work). The low setting on most hot plates is around 140*.
SS Last edited by sswee; 04-22-2006 at 06:15 PM. |
I have been doing a lot of small parts, so I use the rubber made small food stoarge containers (cheap 4 packs like you tak eto work and eat out of) I nuke them in the microwave till I get 140*. It takes about 3 minutes on most of them, I also have some larger ones that may take 6 minutes
Saves a lot of time and power compared to other heating methods, not messy, and so far I have not seen any harm to the dye using the nuker Clint |
| 7000 series parts dye, but 6000 series won't | acidrain | Anodizing Questions | 20 | 11-17-2005 10:19 PM |
| Anodizing Dye pH | mcaswell | Anodizing Questions | 1 | 11-02-2005 11:33 AM |
| sealer on Tiffany green? | jedavies | Other Metal Finishing Questions | 1 | 08-24-2003 03:13 PM |
| blue or green compound for final polish? | shine | Metal Polishing Questions | 1 | 07-26-2003 04:29 PM |
