+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 25
Thread: Masking questions
  1. Masking questions
    O.K. SS, I got my power supply, ran my 1st test part, came out great!!
    So now I'm feeling cocky and I want to try to do 2 colors(splash), I was wondering about the rubber cement, how clean of a line will it give, is there something that will give clean lines and come off easy?
    Also,just so I am clear, you ano, then mask, let dry, then dye(darker colors 1st), then strip off the mask, and dye the next section(lighter color), is this right? All advice is welcome.
    Thanks
    Canute
    Share with Facebook
  2. Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,278
    Re: Masking questions
    Super. The PS make it a bit easier? I know it took away alot of headaches for me.
    Normally lighter colors are done first when doing coatings because the darker colors will cover the lighter colors. As on the sponge work. On this, I haven't done enough to say which way is best. Acidrain or one of the others will be able to tell you from first hand knowledge what worked for them.
    SS
    Share with Facebook
  3. Join Date
    Sep 2004
    Posts
    1,235
    With masking, the first color is dyed, then the mask is applied, then the balance of the first color is removed with bleach, rinse, acid, rinse (repeat if necessary). Don't get the acid contaminated with bleach or vice-versa, or deadly gasses will be released that will literally kill you in a heart-beat.
    Once all of the unwanted dye is removed, go ahead and dye it the second color. Rubber cement makes a very fine line, and so does hot-glue. They are both a bit stringy, though, so be carefull with that.
    BTW, the reason for the double-dip to remove unwanted dye is because dipping in bleach works best for removing color, but will affect the next colors. Acid does not affect the next colors, but doesn't remove the dye very well. Heating to no more than 70F helps as well if it's cold where you are at. Just make sure the parts are rinsed well in seperate containers, and you'll be alright.
    I do things.
    Share with Facebook
  4. Re: Masking questions
    so then once the first dye is in you do not seal yet, correct?
    -matt
    Share with Facebook
  5. Join Date
    Jul 2005
    Posts
    438
    1.anno
    2.dye
    3.mask
    4.let mask dry good (unless sticker)
    5.dip in bleach
    6.rinse good with distilled water
    7.Dip in acid (like acidrain said)
    8.Wash again very good with distilled water
    9.dye 2nd color
    10.seal for a short time
    11.remove mask
    12.seal for rest of time
    13.Spray with WD-40
    I was thinking maybe run the part for 5 minutes or so after it has been masked and bleached to help the ano layer alittle more...Im not the best in this subject yet though....and will rubber cement dry under water?
    Share with Facebook
  6. Join Date
    Sep 2004
    Posts
    1,235
    You have it exactly right, except I didn't understand what you meant by run for 5min longer. Did you mean anodize more, or seal more? I wouldn't do either one. Do it exactly like you described in your steps.
    No, the rubber cement will not dry under water, but you can use a hair dryer to help it (just don't get it up in the 160F+ range.
    I do things.
    Share with Facebook
  7. Re: Masking questions
    does this DAMN thing work??
    Share with Facebook
  8. Re: Masking questions
    Hi guys, thanks for the info. on 2 color.
    I am having problems, again. Heres whats going on:
    70 Degree temp.
    Ecthed parts lye for 3 min.s Parts began to bubble like "aklaseltzer in coca-cola" Removed parts and rinsed in distilled water
    Placed parts in acid solution, turned on power
    SA 23.385 IN sq
    Set amps to .73 as per 720 rule, parts bubbling like crazy
    Starting voltage was 5 volts, never got 11.25 volts as per 720 rule
    At 40 min.s voltage was 5.4 volts
    At 45 min.s voltage was 7.2 volts
    At 50 min.s - 7.7 volts
    At 58 min.s voltage shot up to 18.4 volts, amps dropped to .61
    At 1 hour 10 min.s part #2 is the only one still bubbling (rest stopped)
    At 1 hour 12 mins, Amps dropped to .13 - Volts stayed 18.4V
    Removed parts and rinsed.
    RESULTS - Part 1 & 3 Barely took color
    Part 2 came out a dark pinkish rose color w/ red small lines (Looks almost like cracks, but are not, just looks that way)
    Reran part no, 1, by itself, came out slightly darker, but not as dark as part no. 2
    any help would be apprieciated , Thanks
    Canute
    Share with Facebook
  9. Join Date
    Nov 2004
    Location
    Posts
    1,278
    One of the things with a PS is it shows problems better. You lost connection. Your PS is 18V isn't it. With the numbers you gave, you lost connection when you only had a .4 mil coating.
    SS
    Share with Facebook
  10. Re: Masking questions
    SS, yes, it is 18V.
    I will do better, Thanks
    Canute
    Share with Facebook
+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Thread Information
Users Browsing this Thread
  1. Questions about masking and how the powder stays on
    By UnorthodoxCreations in forum Powder Coating Questions
    Last Post: 10-04-2005, 12:45 AM
  2. Questions about masking and plugging and rectifiers, noob
    By Paintbalaguy in forum Anodizing Questions
    Last Post: 07-18-2005, 09:28 PM
  3. Is thin sheet acrylic ok for masking?
    By ld2222 in forum Electroplating Questions
    Last Post: 12-15-2004, 11:29 PM
  4. A few newbe questions
    By thestormfamily in forum Electroplating Questions
    Last Post: 06-30-2004, 09:54 AM
  5. Masking products for EN plating?
    By edclark in forum Electroplating Questions
    Last Post: 12-23-2003, 04:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
