I have been doing several parts that have threaded holes, after anoddizing before dye I do a pre dye clean, just water and swish the part real good in it back and forth, then right into the dye. Everything perfect, then into the stam/boiling water seal, here is where I have problems, the acid from the anodizing solution must be getting trapped in the small threaded holes, when the hot water/steam hits it, the acid then comes out and bleaches the dye, and of course it's to late for another dye because the part is sealed. Any ideas ?
Clint |
Clint |
I use one of those pump sprayers from the garden department... not a big one with a hose, a little one that holds about a quart (be sure to disassemble and clean REALLY good first). First, I spray rinse the part into the tank, then dunk in the RO water rinse tank. Then, when going to the dye tank, I pull the part and spray into the holes really good... especially if I've threaded into a hole for a connection. Unscrew the hanging wire from the hole, rinse well, then thread back in again (with gloved hands of course).
| Anyone done acid washes? | scamihorn | Anodizing Questions | 34 | 06-08-2006 01:59 AM |
| Acid leach at connection point | mtarrant | Anodizing Questions | 2 | 07-25-2005 10:10 PM |
| Acid | SniperSlayer | Anodizing Questions | 8 | 07-25-2005 09:59 PM |
| Acid copper | Gabourie | Electroplating Questions | 3 | 09-25-2004 08:42 PM |
| Acid concentration versus current density | M_D | Anodizing Questions | 7 | 02-04-2004 09:01 PM |
