Old 04-30-2006, 05:34 PM
Default Autococker Paintball Surface Area
Has anyone bothered to calculate the surface area of a 2003 autococker? If this information is readily avaliable I'd very much appreciate it.
Tomorrow I have to anodize my :
- 2003 System-X WGP Autococker body
- Stock back block
- Stock front block
- Stock vertical regulator
- eBlade grip frame
- Solenoid cover
- Stock eBlade trigger
- Stock ram body
- Stock low pressure regulator body
- Stock low pressure regulator thumb screw
- Dye 3" x 4" drop forward
- Dye ASA
If I had all this stuff here (at home) I would measure it up now but alas, its at the shop and already wired to the rack for anodizing...Shux!
Thanks all...Maybe I'll just "wing it"...LoL
- Dan
Old 04-30-2006, 08:46 PM
destroyer125's Avatar
Default Re: Autococker Paintball Surface Area
should be pretty easy if you have one layin around their pretty square
Calculating Surface Area, the Easy Way. PrecisionPB Anodizing Questions 6 05-28-2005 02:56 PM
Anodizing without knowing surface area? sbpoole Anodizing Questions 3 01-06-2005 07:09 PM
Surface area measurements rwizinsky Anodizing Questions 0 12-20-2003 05:11 PM
surface area for electroless plating tepece Electroplating Questions 1 02-09-2003 07:54 PM
Surface Area vs. Current shorton Electroplating Questions 3 11-06-2002 11:36 AM
