Old 05-05-2006, 08:25 AM
Canute7 is on a distinguished road
Default tank
Hey everyone,
I'm looking for info on tanks, more to the point, what type of plastics will stand up to the solution(s) that are used in LCD ano. All input welcome.
Thanks
Canute
Old 05-05-2006, 09:47 AM
sswee's Avatar
Moderator
Default Re: tank
polypropanol, polyethelene. HDPE - High Density Polyethelene is the prefered.
http://www.usplastic.com/catalog/pro...ookie%5Ftest=1
http://www.plastic-mart.com/class.php?cat=39
SS
Old 05-05-2006, 10:17 PM
Default Re: tank
Thanks for the info, hope to be building my barn soon, if all goes well I could be up and running by July, we will see.
Thanks again
Canute
Old 05-06-2006, 12:39 AM
Default Re: tank
I'm a fan of the polypropylene myself. Easy to weld and holds up nicely. My tanks are 1/2 thick PP sheet which I cut and welded into 45 gal tanks. Ran PP ribs around the top and middle of the tank and they are strong, strong, strong!!
Just my $0.02
- Dan
Old 05-07-2006, 10:25 PM
archimedes is an unknown quantity at this point
Default Re: tank
dan,
I have a friend who is looking to weld poly.
what welder are you using and what do you
recommend for starter supplies ?
thanks,
archi
Old 05-08-2006, 01:29 AM
Default Re: tank
I bought a bottom of the barrel plastic welder. Its a ProTec if I recall. It was cheap but effective. You'll need an air supply (compressor with regulator) to run it. I built my own forced air unit with a small squirrel cage which pushed air through about 20' of light, flexible sump-pump hose. This hose end was fitted to the welder and viola. Other than that, you'll need some welding wire (I used just round, approx. 1/8" dia), a router so you can bevel the edges and make room for the weld bead and side cutters or something to cut the welding rod with. Tell him to make a few practice runs on a piece of scrap...I was making professional weld seams within an hour of playing around. He's gonna have to maintain an approx. 5lbs of downward pressure on the welding rod at all times so his hand is gonna get tired...I hope he drinks beer...It helps! LoL
Cheers!
- Dan
Old 05-08-2006, 09:22 PM
Default Re: tank
dan,
thanks. got it. good enough info to get him going i think.
i will print and take to him.
your info should make him get off the fence . . . . . .
but, i don't know about the beer part!
archi
  #8 (permalink)
Old 05-08-2006, 10:23 PM
Default Re: tank
Mmmmm..........Beeeeeer.........
Anymore questions, just PM me....I'll do what I can.
Cheers!
- Dan
Wires breaking in the ano tank kmbrly Anodizing Questions 12 02-21-2006 08:44 PM
Need opinions on my next tank. jtsuttle Anodizing Questions 4 03-29-2004 12:32 PM
Other materials in Anodizing tank? usao Anodizing Questions 4 03-04-2004 09:07 PM
leaving cathodes in ano tank? Sid03 Anodizing Questions 1 01-26-2004 02:10 PM
Tank Heating Questions. meganine Anodizing Questions 1 08-03-2003 03:20 PM
