I had my first occasion to anodize TIG welded aluminum. I used the proper Lincoln approved filler rod which off the top of my head was 5356. The 6061 of the part anodized perfectly, the weld metal itself anodized perfectly with the same final red colour as the 6061, but the point were the two (I assume) combined turns a bit black, like a shadow following a line beside the weld. If you can imagine a corner weld, the base metal is fine and the weld is fine but there is a shadow along both sides of the weld bead. I did not desmut the part before anodizing.
Has anyone had this experience? Any suggestions? Sage |
greetings sage,
I have seen this problem occur in many instances with machine shops having parts repaired through filler tig welding, re-machined and then anodized. Didn't work out so well. But then I have myself received anodized rims from Buchannan's (maker of Sun rims in CA) had them stripped of the anodize and personally looked straight at a machine made butt weld! But I could not have believed this before I stripped the anodized layer. I think Buchannan's use an anodizer who has figured something out . . . . . Secondly, there is a professional finisher's forum on the internet www.finishing.com and these guys might have some answers or suggestions for you. This is the first place I found some of Fibergeek's discussions regarding the genesis of the LCD system while I was doing my own research. So it seems a pretty knowledgeble resource. 2 areas of interest would be to write a letter of inquiry and/or review the letter's archives. Those archives can be very interesting and rewarding, if you have the time -- there's a lot 'em! hope this helps, archi |
| Hard Anodizing | jamerson | Anodizing Questions | 18 | 02-16-2008 10:59 PM |
| Caswell Deluxe Anodizing Kit with extras minus chemicals | scocklin | Used Items For Sale | 13 | 05-11-2006 07:32 PM |
| CV anodizing and electrolyte Titration | acidrain | Anodizing Questions | 22 | 04-08-2006 02:42 PM |
| Color depth vs. anodizing time | NeoMoses | Anodizing Questions | 17 | 02-03-2004 09:06 PM |
| Anodizing different alloys | TONYZ | Anodizing Questions | 2 | 11-02-2003 01:31 PM |
