I just had a thought... I work at a body shop and own a stud welder. Could that be used to weld Al. wire to the part like a Sput-Welder? Maybe like clip leads to the outside ring for the ground and put the wire into the tip? Any body men out there?
Link to stud welder: http://cgi.ebay.com/ebaymotors/H-S-A...spagenameZWDVW |
I'm not a body man. I've tried using a MIG welder by fitting .046 alum wire into the electrode and dialing the voltage all the way down, but it always vaporizes the wire. My MIG supposedly bottoms at 35 amps, so I suspect you'll have pretty much the same result, but if you already have the stud welder, would it hurt anything to give it a try?
| type 5 sput welder? | Renegade_43 | Anodizing Questions | 0 | 06-28-2005 03:18 PM |
| Sput Welder on Firearms? | adavislock | Anodizing Questions | 2 | 03-27-2005 05:16 PM |
| sput welder | lastone75 | Anodizing Questions | 38 | 03-15-2005 09:48 PM |
| SICK OF BAD CONNECTIONS? SEE THE SPUT WELDER - NOW AVAILABLE | mcaswell | Anodizing Questions | 35 | 12-01-2004 09:59 PM |
| wire welder for power source | elboriqua | Electroplating Questions | 2 | 11-04-2003 06:25 PM |
