Always thinking of upgrades, one way to streamline my setup would be to prepare and start a second run after the first one is started...
I could do this with two complete tank setups, or would this work: Use a second power source with it's own rack in the same tank as the first power source. Both power sources connected to a common cathode (ideal method for me)? Would I have to run a second cathode? I don't see a problem with this, but maybe somebody out there has already learned the hard way.
I think you're more likely to have problems with shadowing. Second thing would be to make sure you don't inadvertently wind up with more aluminum than cathode area, and of course you'll have the potential to create more heat.
The two supplies would fight each other if you connected the anodes, but won't as long as you don't have any shorts anywhere (like racks touching or aluminum from the separate supplies swinging together). You can look up "kirchoff" in a search engine - some of it gets pretty technical but if you look at several different sites you'll get the idear. |
We do that all of the time. Sometimes we have multiple racks for different colors, or different type of parts that are prepped differently, and etc. The volts for each power supply remain consistent with what we see for a single power supply.
| Common negative for more than 1 power supply? | dfarning | Electroplating Questions | 3 | 03-10-2006 02:19 AM |
| Power Supplies | Newton | Electroplating Questions | 6 | 12-15-2004 01:47 AM |
| Cheap power supplies | MrDmB | Electroplating Questions | 2 | 05-03-2004 11:55 PM |
| Multiple power supplies | rwizinsky | Anodizing Questions | 1 | 01-20-2004 07:20 PM |
| Appropriate power supplies | potsked | Anodizing Questions | 3 | 12-13-2003 05:21 PM |
