Old 06-11-2006, 11:19 AM
anodizeme4ever is on a distinguished road
Question Cathode
Can anyone tell me which makes the best cathode - aluminum or lead? I'm in the process of setting up a large rectangular tank and want to make sure I have the best before proceeeding(for obvious reasons).
Thanks,
Kevin
Old 06-11-2006, 12:06 PM
rclint is an unknown quantity at this point
Default Re: Cathode
Lead, last much longer
Old 06-11-2006, 12:29 PM
Default Re: Cathode
Lead generates more heat in the tank, leeches lead into the water producing hazardous waste and has a higher degree of resistance meaning it is not as efficient as aluminum.
Go with aluminum...A far better choice!
- Dan
View My Anodizing Line
Old 06-11-2006, 04:31 PM
cameraman is on a distinguished road
Default Re: Cathode
Could you please quantify this? Let's say a 10 gallon 1'x2' well insulated (assume no temperature difference due to environment) tank, anodize 100 in² at 6 a/ft² to 1 mil. What would be the temperature differential between lead cathodes and aluminum cathodes - 1°, 5°, 10°? Me and heat are having a big fight these days, so if it's going to be a significant difference I would consider switching - but actually, it's initial tank temp that's giving me fits; I don't seem to experience any significant rise over the course of the run.
It's not waste until you're finished with it and trying to get rid of it, which isn't going to happen until you've anodized several hundred square feet. I considered my tank "hazardous waste" the moment I poured sulfuric acid into it - even if I neutralized it I wouldn't pour it down the sink or toss it in the alley. With or without lead it will go to a hazardous waste facility once it's got too much dissolved aluminum to be useful. It would seem to me that it would be cheap and easy to reclaim the lead. They'll either reclaim the metals or dispose of them safely, so I'm not seeing how this is an issue.
I'm neither a chemical nor environmental engineer, so 'head-on-backwards' is a definite possibility...
Old 06-12-2006, 11:19 AM
Default Re: Cathode
Due to lead having a greater electrical resistance than aluminum, higher voltages are required thus generating more heat in the tank. What the temperature difference would be in your case I have no way of knowing. There may be a mathematical answer to your question but I do not know what it is...
You made three points in the above paragraph and I'm sorry to inform you that all three are incorrect. Atleast from my standpoint.
1. "It's not waste until you're finished with it and trying to get rid of it..." Perhaps one should consider the possibility of leakage due to tank rupture, accidental spillage, dragout into the rinse water which then becomes contaminated with lead. The various methods of lead being introduced into the environment are endless if not monitored very carefully and religiously. Lead is bad for the environment, m'kay.
2. "...isn't going to happen until you've anodized several hundred square feet." Lead leeches into the solution whether you've anodized 1 square inch of surface area or 1000 square feet. Lead is a very carefully monitored substance in my part of the world...Infact waste waters or pickling solutions containing lead (or any heavy metals) are monitored on a government level - they are hazardous waste! I'm not comfortable dumping any amount of hazardous waste in anyone's backyard. I'm also not comfortable to hear of other people doing it. Please be responsible.
3. "I consider my tank "hazardous waste" the moment I poured sulfuric acid into it - even if I neutralized it I wouldn't pour it down the sink or toss it in the alley." Well tossing it the alley might get the neighbours to look at you funny, however, if it were properly neutralized it's not much more dangerous than water. As my anodizing line is of a large enough scale that I have to keep tabs with the city, I learned that as long as the pH levels of ANY of my anodizing baths is in the 6.8-7.2 pH range (I'd have to go back into my records to double check those exact levels) that I can pour it directly into the sewer system - unless I exceed 40,000 gals per year in which case I would have to send it to a treatment plant for processing.
In my opinion, for the most part people who experiment with anodizing and electroplating in their backyards are responsible people. Having said that, there seems to be a select few who feel that dumping their pickling baths in their backyard or down the drain is an acceptable practice. Perhaps this stems from a lack of understanding of just what it is that they are "playing" with. I personally feel that the first thing one should research is the environmental issues that your latest interest may hold. Not only would the individual better learn how to protect his backyard but his/her own health.
I don't mean to say that you seem like one of these people who goes around dumping your pickling solutions in the yard...Don't get me wrong. I'm simply trying to argue the point of how wrong it is...On so many levels.
Just my $0.02. Stepping off my soap box now...
- Dan
Old 06-13-2006, 05:25 AM
Default Re: Cathode
That's a bummer, I thought you had information that I didn't. So it could quite conceivably be .1° or so small as to be immeasurable outside a laboratory.
I apparently didn't explain this thoroughly enough. I said that you aren't going to try to get rid of it until you've anodized several hundred square feet. The point is that it doesn't pose a problem until you need it to go somewhere else. Unless you're staring at an LCD screen, the CRT monitor you're looking at right now contains lead, barium, cadmium, phosphorous, and mercury. While it's sitting on your desk it isn't a problem. If you throw it in a landfill when it dies, it becomes a problem. Likewise, the lead sitting in the bottom of the tank isn't a problem while the solution is in service - and actually, we don't even know at what rate that's happening - it's quite possible that we're only looking at 1 ppm after 1000 square feet. I don't have a rinse tank. If my ano tank ruptured, I'd clean it up.
not much more dangerous than water... with the city, I learned that as long as the pH levels of ANY of my anodizing baths is in the 6.8-7.2 pH range... I can pour it directly into the sewer system
Well, I guess we'll just have to agree to disagree there. The only way my stuff would end up in the sewer is if the hazardous waste people put it there.
This is making my head hurt - probably in part due to lead poisoning, I'm sure. Bottom line is you recommend Al plates, I recommend Pb plates, and it sounds like both our alleys are safe [from us].
Old 06-13-2006, 11:09 AM
Default Re: Cathode
We seem to be hijacking Kevin's thread and arguing back and forth...So, to bring your question to the surface and answer it again Kevin :
My suggestion to you is to call your local anodizing outfit, heck call several. Ask them what they use for cathode material. If it is a modern shop (chances are even if it is an older shop), the answer will almost always be that they are using a 6000 series aluminum for their bus bars and cathodes.
They must be using aluminum for a reason...Fact is, its for the same reasons I mentioned above.
- Efficiency (less electrical resistance)
- Heat build up (due to the electrical resistance being lower)
- Less recitifer strain (due to the electrical resistance being lower)
- Avoids lead contamination
- Ease & economics of waste water treatment (lead free)
It is true that I have never used lead as a cathode in my operation. Having said that, I can't think of one single benefit to using lead over aluminum. Someone said that lead lasts longer. This may be a possibility (and it may not be, for argumental purposes I'll go along with it) but when you consider that your cathode MAY need to be changed once every few years, I'm not sure the pros out-weight the cons here.
And in direct response to some of your comments cameraman :
It may be true that the CRT monitor that I am looking at right now contains lead in conjunction with several other deadly chemicals, however, the same monitor I am looking at was engineered to safely contain these chemicals. Furthermore, this same monitor was tested prior to marketing to ensure a safe product. Engineered and tested! Going on, each and every monitor which has hit the store shelf has passed a Quality Control process in which the entire product is inspected for defects. Needless to say, a monitor posses much less risk of accidental leakage than say something such as a home made anodizing tank. The chance of accidental leakage, rupture, spillage, dragout are much greater with a large, open container - particularily one which has not been engineered or tested for the specific task at hand. Bare in mind that you are not in direct contact with the chemicals inside your monitor. You are in constant proximity to the chemicals within your anodizing tank. My last point will be this...Regarding your CRT monitor, when it does cease to function and it is no long of any use to you - generally it would go to the dump. Every landfill I've been to in the last few years has a designated place for things of this nature though some people choose to kick them off the back of the truck and bury it under more debris. Thats what those filthy people who work at the landfill do...They are paid to be responsible for those of us who aren't. They pick your monitor out of the trash pile and seperate it. Bottom line, it falls on the responsibility of the individual...
I recognize your point here cameraman. You argue that the solution shouldn't become a problem until your choose to dispose of it. I don't disagree with you, however, I also feel that one should take into consideration the "act of god". Accidents happen and I strongly feel that one should be prepared and educated for such an event. You suggest that in the event that your tank raptured that you would simply clean up the spill. Do you know how to clean trace amounts of lead from off a concrete floor? You also bring to the table the possibility of there being only 1 ppm lead in the solution after anodizing 1000 sqft of material. Regardless of the quantity, it is still a regulated waste.
You say you don't have a rinse tank...I must assume at this point that you rinse your parts after anodizing under the tap. Where do you think those contaminants go when they run down the drain? They don't get delivered to the hazardous waste tratement facility thats for sure...Agreed, the quantity of lead may or may not be very minute, however, it all adds up at the end of the day...
I won't disagree with you but rather bluntly point out to you that you are wrong. It would seem as though that you have a difficult time accepting that. We all do from time to time and I'm no exception. The only reason I can say to you that you are wrong with any confidence at all is that I had a meeting not too long ago with a few representatives from my city council. The individual responsible for environmental sewer control directly told me that I could dump up to 40,000 gals of my anodizing baths directly into the sewer system providing that their pH levels were adjusted accordingly. That's not to say that I do dump my baths into the sewer but rather I could if I so choose. I later went on to speak with a local hazardous waste treatement facility here in the city and was told the very same thing. So infact, if I did bring my solutions to the hazardous waste facility, I would be paying them to dump it down the sewer (after pH adjustments of course). Simply put, where I am located, your statements do not hold true sir.
I will take this time to apologize if I seem to be coming off like a "pushy, know-it-all". My intentions are good I ensure you cameraman and infact I make no claim to "know-it-all". Quite the contrary as a matter of fact. As I have made anodizing my full time job and my life, I learn new stuff regarding anodizing on a daily basis. I did in fact point out to you that you were incorrect in regards to sewer dumpage, however, I also realize that the regulations may be very different in your current location. I accept and apperciate your arguements. The way I see it we can learn much from eachother.
Good luck anodizeme4ever! Let us know which road you travel...
- Dan
  #8 (permalink)
Old 06-13-2006, 01:31 PM
Post Re: Cathode
OK you guys, I hope you're done now! Not sure if I want to ask anymore questions.
I'm really leaning towards the aluminum as it makes more sense than having to deal with lead.
Thanks all for the info.
  #9 (permalink)
Old 06-13-2006, 02:00 PM
Default Re: Cathode
Awe...We're not fighting anodizeme4ever... We're simply having an educated conversation in which two individuals each have their own opinion(s). We're expressing why we feel one is better than the other. It's a wonderfull way to learn and can be quite humbling at times. Don't mistake a debate for a fight. We're all grown ups here. No worries! Infact, I appreciate cameraman's arguements - I really do.
Don't be affraid to ask questions. Almost anything and everything you ask will have a "debateable" twist to it. We can't all do things the same way now can we? This is what makes life interesting, educational and forever fresh....
Cheers!
- Dan
  #10 (permalink)
Old 06-13-2006, 06:09 PM
Thumbs up Re: Cathode
Dan, I didn't realize that it was you that had been replying - I've seen your setup and have been drooling just thinking about the day ous will look like that - what a professional looking set-up!!!
I'm sure I'll be in contact for more info as our business starts to grow and will be in need of more advice.
Thanks again to all for the advice.
Kevin
using aluminum as a cathode scocklin Anodizing Questions 19 03-31-2007 01:18 AM
Cathode size R-Wells Anodizing Questions 7 04-22-2006 07:18 PM
No laughing.. cathode type? hefrod Electroplating Questions 1 08-17-2005 03:31 AM
Distance to cathode PeterM Anodizing Questions 2 10-01-2004 02:43 AM
work area vs. cathode area elton10 Anodizing Questions 4 03-25-2004 10:59 PM
