I have purchased a sput welder and have done some practicing with it... But up to this point I'm dissapointed in the welds I get... Can any one give me some pointers in its use... Seems the welds are very unstable and any lateral movement will break them... Not sure they would last in the ano bath.... What gauge of wire should I be using? Thanks for any help...Ross
I have also found that it is best to thoroughly wet the surface, so that the impact of the wire goes through a liquid drop. This improves the weld, reduces splutter and leaves a smaller scar.
I've never used a sput welder, and I don't know what the instructions say about it either, but I do a lot of TIG welding and the biggest problem with welding aluminum is the ozide layer that forms on it and inhibits the welding process. The water drop I can uderstand becasue it would shield the aluminum from the air around before and during the weld process. I would add also that thoroughly cleaning the aluminum piece and the end of the wire if possible under water, and keeping them wet so no air can reach them up to the time you perform the weld might help as well. In TIG welding argon is used to shield the weld and the AC current cleans the weld area while the argon is present to stop air until the metal melts and/or the filler rod is addded.
Sage |
| type 5 sput welder? | Renegade_43 | Anodizing Questions | 0 | 06-28-2005 03:18 PM |
| Sput Welder on Firearms? | adavislock | Anodizing Questions | 2 | 03-27-2005 05:16 PM |
| sput welder | lastone75 | Anodizing Questions | 38 | 03-15-2005 09:48 PM |
| SICK OF BAD CONNECTIONS? SEE THE SPUT WELDER - NOW AVAILABLE | mcaswell | Anodizing Questions | 35 | 12-01-2004 09:59 PM |
