OK I spoke to someone today about hanging plates and I just wanted to confirm the answer.
If I have an aluminum "plate" that is 8''X4'' I should start my 720 rule with approx 64 sq inches before I add any parts. Is this correct? I was told if I didnt want to anodize the ''plate'' not to include the SA in my calculations...... With that said if I use titainium plates I will only need the SA of what I am hanging to be anodized...... |
there is a rule:
For proper anodizing without worrying about shadow effect you should use a 4 cathode: 1 part SA ratio. I find when i break this rule, my cathodes bubble like nuts and being stressed. With the 4:1 ratio, everything works better. |
The plate is attached to the cathode. It is used to hold the parts in the ano solution. So auctually it does get anodized, that is why I wasnt sure. |
I have an aluminum bar across the tank with al. wire attached to it. The al. wire is then screwed to the plate. So the plate with the parts attached and a small portion of the hanger wire are submersed in the solution.
SSWEE..
You got it the cathode was brought up in previous post. But yes the rack is attached to the anode. You also answered my question, the SA shouldnt need to be figured using Ti racks. You did mention unless there was a large differnce? The ti plate will be 8'' X 4'' with small fingers on each side where I will have small parts ''pinched'' in between them. Total SA to be anodized maybe 30 sq. inches at the most. Would you consider that a large differnce? |
| raplacement for GP plates ? | jtagger19 | Electroplating Questions | 2 | 06-05-2005 06:49 PM |
| GP Plates and Dummy Plate | Tim1hd | Electroplating Questions | 2 | 03-12-2005 08:32 AM |
| Steel or Nickel facing onto zinc plates | bridgepress | Electroplating Questions | 0 | 11-06-2003 05:28 PM |
| Black Oxide concentrate, how durable on carb throttle plates | KenL | Electroplating Questions | 1 | 10-09-2003 08:42 PM |
| copper plates | dcarter | Electroplating Questions | 1 | 01-18-2002 08:58 AM |
