Old 07-11-2006, 01:28 PM
krymis is on a distinguished road
Default amps not going up
I racked some new rc parts and went through the process upto anodizing. I turned my ps on and cranked the volts up to 15v slowly, but the amps never went up past 1 amp. they were in for 1 hr. What should i be checking? I used radio shack alum. wire for racking, cleaned all connections from power supply, etched the cathodes...one part started to turn a light brown. I just don't understand. Help please.
Old 07-11-2006, 02:16 PM
Default Re: amps not going up
You should be calculating the amps with the 720 rule (stickied at the top), and controlling the amps, not the volts.
However, if you insist on running in CV, the amps will adjust themselves to the size of the part. Try measuring the surface area, and calculate what the amps should have been, and compare that with what your actual amps were.
Old 07-22-2006, 11:57 PM
mcaswell's Avatar
Caswell Inc Founder
How did you actually make the connection to the workpiece?
Have A Web Site?
amps / sq. in. johnmorgan Anodizing Questions 27 06-19-2006 02:18 AM
control amps by cathode size destroyer125 Anodizing Questions 5 04-13-2006 09:39 PM
How many amps? TreyY Oven Building Forum 12 04-02-2006 02:46 PM
Amps at battery or under load? Techno Electroplating Questions 1 08-09-2005 11:01 PM
HOW MANY AMPS ? Conflicting info ASHENASH Electroplating Questions 4 06-21-2005 01:46 PM
