Old 07-14-2006, 10:59 AM
pmac2002 is on a distinguished road
Default what to do...to get a flat finish!
Ok guys I have a shocker and it is kinda beat up!...so to cover the blemishes...do i just have it sandbalsted to make the dust finish?
thanks
Paul
Old 07-14-2006, 12:13 PM
Default Re: what to do...to get a flat finish!
No, sand blasting would be bad. You can bead blast it with very fine glass beads, but it only removes the finest of blemishes. Your best bet would be to sand out the nicks and scratches with fine sand paper, then polish out the blemishes. Polishing with a sisal wheel and black compound will remove quite a lot of material. After that you can go to bead blast or finer polish.
If you don't have the equipment, you might consider paying somebody to do it for you. Keep in mind, the glass beads must be the correct size, and applied with the correct pressure and distance, or the piece will be blotchy.
Old 07-14-2006, 05:22 PM
rclint is an unknown quantity at this point
Agree 100%, trying to cover up spots with bead blast works on a lot of things, even aluminum, that is until you anodize it, then the spots stick out bad like
One way I have found to cover the semi pitted surfaces is a brushed finish, this has worked the best for me, even then I try to get a better finish by sand paper, polish, etc
Old 07-15-2006, 07:06 PM
what size glass beads would be used?
thanks
Paul
why flat finish fragglerock Anodizing Questions 14 04-06-2006 01:23 AM
Golf Clubs - How to remove nickel finish prior to refinishin doctordave Other Metal Finishing Questions 3 06-03-2005 03:21 PM
Flat black powder? wozzwinkl Powder Coating Questions 10 04-05-2005 12:37 AM
Newbie, trying to find best way to finish aluminum-LONG POST chik Metal Polishing Questions 6 03-14-2005 08:11 PM
can we identify this finish? funkmunky Electroplating Questions 3 12-15-2004 08:45 PM
