  #21 (permalink)
Old 07-26-2006, 07:25 PM
larryp is on a distinguished road
Default 7/26 results
Just to let ya'll know, the redo today of yesterdays parts turned out even lovelier than yesterday. Thanks again for getting me going, Larry
  #22 (permalink)
Old 07-26-2006, 07:48 PM
archimedes is an unknown quantity at this point
Default Re: Direction to previous posts
Greetings Larry,
Congrats on your progress.
As for adjusting Ph values I use Muriatic acid to lower the Ph
and Ammonia to raise the Ph values.
Using a plastic syringe (w/o needle) with a 3 gal Dye level,
it takes about 20 drops of either to increment the Ph value +-.1 with
a good stir after a "set" of drops before measuring, and
rinsing the electronic Ph tester bulb with De-Ion water b/t successive
measurements.
And don't forget to record the Ph value for your chosen dye on
each ano run.
As an example for my system; using Black dye I ran test batches
from 5.7, 6.2, 6.4, & 6.7. Another post of mine depicts the "blueness"
of the results for my system at Ph levels 6.2 and lower with a Ph at
6.4 resulting in an optimized color saturation in my opinion.
I have just begun my red dye optimization and I immediately set the
Ph value to 6.4, based on the opinions gleaned from archived posts
and my own intuition.
There are many excellent posts depicting the dye issue and I learned a
great deal from reviewing them. Black and Red dye results have been
keenly dissected by some knoweledgeable participants in this forum.
archi
  #23 (permalink)
Old 07-27-2006, 10:06 AM
archimedes,Thx for dye info. And a good morning to all. Larry
Need a little direction fatboyz Electroplating Questions 3 05-04-2006 12:06 AM
Any direction? Deecoat Powder Coating Questions 3 01-30-2006 05:47 PM
Thanks for the informative posts bkoenig Powder Coating Questions 16 02-15-2005 08:34 AM
Removing previous Anodized Coating viper753 Other Metal Finishing Questions 3 03-03-2003 11:33 PM
buffing direction hue Metal Polishing Questions 2 02-23-2003 11:28 PM
