I am looking to determine how to reduce the amount of visible fingerprint appearing on an anodized sheet of aluminum with a radial brushing pattern. I have been told previously that it has something to do with my sealing process however I was looking for something a little more precise. Is there a specfic sealing solution, sealing temp and sealing time I should be using or if there is another step in the process I should be altering.
I would like to thank you all in advance for any assistance you can offer. |
The problem is coming after the anodizing process when we are handling the parts. I do not believe this is a pre-treatment issue. I have not seen this problem on other anodized aluminum parts before but when i have seen prints they were easily wiped off.
These parts are on anodizing racks throughout the entire process and are not handled at all with bare hands until they are received in my office for review. Like I mentioned before, I have seen prints on other anodized aluminum part but the prints were easily removed when wiped. This is why I think it is a processing problem.
What alloy, CD, tank temp, and sealing process are you currently using?
It could be desolution... is the surface chalky? It could be lack of thorough sealing... are you steam sealing, or using the nickel acetate high temp sealer? I use the nickel sealer at near boiling temp for 20min for .75mil, and 30min for 1mil ano thickness.
I have been waiting for confirmation on the chemical solutions in our pre-treatment baths however this is what i do know about our current process. Anodizing tanks are running at 90 - 95 C, We are using a Ni acetate sealing solution which varries by color our high gloss Black runs for 3 mins @ 95 C and are matte grey color runs at 4 min @ 80 C.
Some of my initial thoughts are that the texture on the aluminum is effecting the anodizing process. Our gloss black has a radial brushing pattern and our matte grey has a horizontal brushing pattern. How much do these patterns effect or alter the anodizing process? I know we have made alterations during the pre-treat to insure we do not dull the pattern from the acidic components in the pre-treatment baths. Once again thank you |
The brushed texture will not cause the problem you have described. I think acidrain is thinking the same thing I am, if your sealing times are 3 - 4 minutes total that is likely the problem. That is not nearly enough time, 15-30 minutes is best, depending on anodized layer thickness and etc.
When I first read this, I thought it must be a sealing problem. Parts that are not sealed or not sealed well will likely feel sticky to the touch, especially if there is any moisture present on your fingers or in the parts pores. This is not to say if the part doesn't feel sticky that it is sealed well. |
| clear coating polished alum | hybred | Metal Polishing Questions | 7 | 08-08-2005 02:58 PM |
| powder of polished alum? | hybred | Powder Coating Questions | 3 | 08-07-2005 02:38 PM |
| how do i tell if something is anodized? | rancidnsx | Anodizing Questions | 1 | 01-14-2005 07:56 AM |
| Red dye issues | M_D | Anodizing Questions | 5 | 02-01-2004 11:44 AM |
| Anodized handgun frame | Werew | Anodizing Questions | 1 | 01-26-2003 07:11 AM |
