+ Reply to Thread
Results 1 to 6 of 6
Thread: Painting aluminium?
  1. #1
    Default Painting aluminium?
    Hi,
    I have a project to paint aluminium flat bar stock pieces in a wrinkle finish type paint.
    Question is do I anodise the parts which will give a better surface to adhere paint to but is it worth sealing the aluminium as it will be oversprayed with cellouse paint ?
    And does sealing the aluminium spoil the surface adhesion for the paint?
    Best Regards
    Rick.
    Share with Facebook
  2. #2
    Join Date
    Jul 2005
    Posts
    438
    Default Re: Painting aluminium?
    I would believe sealing the aluminum would ruin the effect
    Share with Facebook
  3. #3
    Join Date
    Jul 2005
    Posts
    495
    Default Re: Painting aluminum?
    rick201,
    I used paint stripper on an aluminum valve cover, stripped the paint off, cleaned it up, sprayed wrinkle paint on, and then clear. It came out beautiful!
    NOTE: All wrinkle paint is not the same. I shot some VHT brand paint (I believe), on an air cleaner, the more coats you put on the more wrinkled it got, I was not happy with the results.
    John
    Share with Facebook
  4. #4
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,283
    My 2 cents,
    I'd leave it unsealed.
    SS
    Share with Facebook
  5. #5
    Hi All,
    Well im thinking that unsealed would be better because if you think there are tiny holes or pores then by not sealing them and spraying the paint onto it hopefully the holes would provide a better base microscopically for the paint to stick to.
    Im going along to the spray paint outlet tomorrow to check out the wrinkle finish paint I will buy it in a litre tin and use me spray gun.
    Rick.
    Share with Facebook
  6. #6
    Join Date
    Mar 2006
    Posts
    126
    unsealed would be best, you can also beadblast or lightly scuff the aluminum and it will provide good adhesion. If your really getting technical you can get some metal primers from a specialty car parts store that has a paint section attached. Be sure to properly clean the surface still.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Type of Aluminium.
    By PeterM in forum Anodizing Questions
    Last Post: 10-14-2004, 04:57 AM
  2. streamlining sanding of cast aluminium parts
    By rotorman in forum Metal Polishing Questions
    Last Post: 05-22-2004, 12:09 AM
  3. Aluminium Motorcycle Forks
    By gjricc2 in forum Metal Polishing Questions
    Last Post: 12-01-2003, 03:56 PM
  4. Engravings ands anodised aluminium - off the beaten track
    By whistule in forum Anodizing Questions
    Last Post: 11-28-2003, 10:45 AM
  5. directions for polishing the aluminium parts on my sportbike
    By mrnasti69 in forum Metal Polishing Questions
    Last Post: 04-29-2003, 08:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
