Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 09-03-2006, 09:29 PM
hurricaneracing is on a distinguished road
Default Power supply
OK too lazy to find prev. post. I am looking at a 30 volt 20 amp and a 50 volt 20 amp. Do I really need 50 volts?
Old 09-03-2006, 09:33 PM
sswee's Avatar
Moderator
Default Re: Power supply
30 volts is good enough for almost a 12A CD. Unless you want to run a higher CD, the 30V will work fine.
SS
Old 09-03-2006, 09:36 PM
SS
Dont mean to be picky, do you mean 30 volt or should I be looking for 30 AMP I am using a CD of 6.
Old 09-03-2006, 09:42 PM
sswee's Avatar
Moderator
The current density you want to run is what determines the voltage needed. The amount of amps is determined by the size of part you'll be running.
SS
Closed Thread
Building power supply from manual dfarning Other Metal Finishing Questions 0 02-19-2006 12:56 PM
power supply Techno Electroplating Questions 0 09-20-2005 09:58 PM
anno power supply jasonboulanger Anodizing Questions 2 01-07-2005 06:48 PM
Power supply aalamo Electroplating Questions 5 11-24-2004 10:21 AM
Anodizing Power Supply Q's jnbsystems Anodizing Questions 7 10-02-2003 11:33 PM
