Old 09-04-2006, 06:52 PM
hurricaneracing is on a distinguished road
Default Why does this happen with ti plates?
I have been using alu. racking for small parts. Finally decided to try my Ti racks. After running them by themselves I found I would nrrd to add .22 amp. I have been running the same product all weekend. With the ti plates it is 6" SA because of the alu racks I need to run 72 SA.
The problem:
When I use the alu. I can run my power supply at 3.30 amp @4-7 volts for the duration.
When I use the ti I tried ti run .72 to shorten the run time. But the power supply maxes out at 15.5 volts and will only put out maybe .30 amps.
I thought maybe it was connection but every run does this? Is there something I should be doing differnt with the ti racking?
Old 09-04-2006, 08:17 PM
sswee's Avatar
Moderator
Default Re: Why does this happen with ti plates?
How close is your SA measurements. What CD are you using?
SS
Old 09-04-2006, 09:31 PM
SA should be right on. I am running a CD of 6. The only differnce is I have to add 64SA to the al. racking.
Old 09-04-2006, 10:28 PM
sswee's Avatar
Moderator
Racking with Ti I haven't seen any differences electrically. Going by the info you give, I have a possibility.
For a 6 ASF, a 15V peak +-4V is normal. The lower voltage you get with alum. rack could be from a high conductivity of the alum plate due to it's size and/or grade. This is providing that the other parameters are fairly consistent.
If I were in your shoes I would drop the CD down to 4.5 ASF and give it a try. It'll give you a calculated peak voltage of 11.25V and still have room for resistance in the circuit before maxing out your PS. I know it'll take longer but it may answer some questions.
Do most of your runs usually have about the same peak voltage without the racking?
SS
Titianium plates hurricaneracing Anodizing Questions 15 07-03-2006 11:33 AM
raplacement for GP plates ? jtagger19 Electroplating Questions 2 06-05-2005 05:49 PM
GP Plates and Dummy Plate Tim1hd Electroplating Questions 2 03-12-2005 07:32 AM
Steel or Nickel facing onto zinc plates bridgepress Electroplating Questions 0 11-06-2003 04:28 PM
Black Oxide concentrate, how durable on carb throttle plates KenL Electroplating Questions 1 10-09-2003 07:42 PM
