Go Back   Caswell Inc. Metal Finishing Forums > Anodizing Questions
Connect with Facebook
Closed Thread
Old 09-24-2006, 12:49 PM
Thefool is on a distinguished road
Default Vinyl Masking
Can someone outline the prossess of making a vinyl mask?
Old 09-24-2006, 02:48 PM
acidrain's Avatar
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: Vinyl Masking
Making the mask is easy... just cut out a mask shape from some vinyl material, and use it as a mask. Here are some tricks:
Not all vinyl is created equally. The adhesives vary. Stay away from low stick, or water soluble adhesives.
The positioning backers used to apply the vinyl (to help it hold it's shape) will leave a glue residue, and contaminate the surrounding surface... don't use it!
You'll want to experimant before trying this on any good stuff... here is the process:
1) Ano, and dye the part the graphic color.
2) Apply the mask.
3) Dip in 100% bleach, and rinse well.
4) Dip in 25% Sulfuric acid, and rinse well.
5) Repeat steps 3&4 until all trace of dye is removed (DANGER, do not mix bleach and acid, even rinse water... POISON).
6) Dye the surrounding color.
7) Seal normally.
Pull the mask, and remove glue residue with lacquer thinner.
9) Continue sealing for an additional 10min.
If bleach has seeped under thye edges of the mask (it will leave a silver ring), the vinyl was not the right stuff.
As always, avoid contaminating the raw ano... always use gloves, clean rags, and clean laquer thinner.
GL -Acid
I do things.
Old 09-24-2006, 04:08 PM
So for masks use vinyl and for splash use rubber cement? Do you have any names of good vinyl?
Old 09-24-2006, 09:04 PM
acidrain's Avatar
I have a plotter/cutter that I use for my masks. The best vinyl I have come accross is 3M graphic film.
I do things.
Closed Thread
Masking products? SX Paintball Anodizing Questions 4 02-14-2007 01:59 AM
my first attempt at vinyl masking destroyer125 Anodizing Questions 1 05-12-2006 11:10 PM
Is thin sheet acrylic ok for masking? ld2222 Electroplating Questions 1 12-15-2004 11:29 PM
Masking products for EN plating? edclark Electroplating Questions 0 12-23-2003 04:41 PM
Looking for masking tape recomendations. chcarver Metal Polishing Questions 0 03-06-2003 03:51 PM
